Bluescreen problem
qwerqwtasd [80.242.33.xxx], 19.03.2017 11:25, Operační systémy, 7 odpovědí (230 zobrazení)
Dobrý deň mam problem vždy pri zapnuti PC dava pasiky po obrazovke a potom hodi bluescreen skušal som preinštalovat OS ale nepomohlo vždy po nainstalovani ovladačov na grafiku to robi zase
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1051
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA800562B010
BCP2: FFFFF88004101CAC
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\031917-25537-01.dmp
C:\Users\Martin\AppData\Local\Temp\WER-37970-0.sys data.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clci d=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Neviem či je to SW alebo HW može mi niekto povedať ? tu je ten minidump
<?xml version="1.0" encoding="UNICODE"?>
-<SYSTEMINFO>
-<SYSTEM>
<OSNAME>Windows 7 Ultimate Professional</OSNAME>
<OSVER>6.1.7601 1.0</OSVER>
<OSLANGUAGE>1051</OSLANGUAGE>
<ARCHITECTURE>9</ARCHITECTURE>
<PRODUCTTYPE>1</PRODUCTTYPE>
</SYSTEM>
<MEMORYDIAGNOSTIC> </MEMORYDIAGNOSTIC>
-<DEVICES>
-<DEVICE>
<DESCRIPTION>ACPI Thermal Zone</DESCRIPTION>
<HARDWAREID>ACPI\ThermalZone</HARDWAREID>
</DEVICE>
-<DEVICE>
<DESCRIPTION>Generic volume shadow copy</DESCRIPTION>
<HARDWAREID>STORAGE\VolumeSnapshot</HARDWAREID>
</DEVICE>
-<DEVICE>
<DESCRIPTION>Generic USB Hub</DESCRIPTION>
<HARDWAREID>USB\VID_8087&PID_0024&REV_0000</HARDWA REID>
<SERVICE>usbhub</SERVICE>
<DRIVER>usbhub.sys</DRIVER>
</DEVICE>
-<DEVICE>
</DEVICE>
-<DEVICE>
<DESCRIPTION>IDE Channel</DESCRIPTION>
<HARDWAREID>Intel-1c08</HARDWAREID>
<SERVICE>atapi</SERVICE>
<DRIVER>atapi.sys</DRIVER>
</DEVICE>
Odpovědět
PředmětAutorDatum
Re: Bluescreen problem Jan Fiala19.03.2017 11:32
Re: Bluescreen problem lední brtník19.03.2017 11:40
Re: Bluescreen problem qweasd19.03.2017 11:54
Re: Bluescreen problem audax19.03.2017 12:06
Re: Bluescreen problem qweasd19.03.2017 12:13
Re: Bluescreen problem qweasd19.03.2017 14:52
Re: Bluescreen problem poslednílední brtník19.03.2017 18:51
Administrátor Jan Fiala, 19.03.2017 11:32
Z toho, co jsi poslal toho moc nezjistis. Bud si stahni DMP file analyzer a zjisti, co zpusobuje problem nebo si precti informace primo na BlueScreen - tam je cislo chyby, obvykle i jmena souboru ovladace, ktere chybu zpusobily.
Všichni chtějí vaše dobro. Nedejte si ho vzít!
↑ Odpovědět
Zlatý rádce lední brtník, 19.03.2017 11:40
Windows 7 Ultimate
úplně typické.
BCCode: 116
může to být vadná tajná grafika, ale úplně stejně i nenainstalované ovladače základní desky - vypisuje ti to samé periferie chipsetu.
poštvi na to raději: nirsoft bsod viewer.
mimidump výpis může mít 64kb, to jsi sem dal hodně stručný výcuc.
wunderbär
↑ Odpovědět
qweasd [80.242.33.xxx], 19.03.2017 11:54
Ano dakujem za odpoveď musel som dat len ten začiatok lebo sa to sem nedalo dať cele lebo to bolo moc dlhe toto spravil ten analyser
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa800564f4e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88003e0ccac, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
FAULTING_IP:
atikmpag+ccac
fffff880`03e0ccac 4883ec28 sub rsp,28h
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`03c06888 fffff880`040a7140 : 00000000`00000116 fffffa80`0564f4e0 fffff880`03e0ccac 00000000`00000000 : nt!KeBugCheckEx
fffff880`03c06890 fffff880`040a6e4a : fffff880`03e0ccac fffffa80`0564f4e0 fffffa80`052bec00 fffffa80`0490e410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`03c068d0 fffff880`0414df13 : fffffa80`0564f4e0 00000000`00000000 fffffa80`052bec00 fffffa80`0490e410 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`03c06900 fffff880`04177cf1 : 00000000`ffffffff 00000000`00000518 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`03c069e0 fffff880`04176437 : 00000000`00000102 00000000`00000001 00000000`00000518 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`03c06a10 fffff880`041492d2 : ffffffff`ff676980 fffffa80`0490e410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`03c06ab0 fffff880`04175ff6 : 00000000`00000000 00000000`0000000f 00000000`00000080 fffffa80`0530b728 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`03c06bc0 fffff800`02f75d6a : 00000000`03ad3dd5 fffffa80`055aa760 fffffa80`036ee450 fffffa80`055aa760 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`03c06c00 fffff800`02cc8266 : fffff800`02e54e80 fffffa80`055aa760 fffff800`02e62cc0 fffff880`031a8150 : nt!PspSystemThreadStartup+0x5a
fffff880`03c06c40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+ccac
SYMBOL_NAME: atikmpag+ccac
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 55c01884
FAILURE_BUCKET_ID: X64_0x116_IMAGE_atikmpag.sys
Followup: MachineOwner
↑ Odpovědět
Zlatý rádce audax, 19.03.2017 12:06
bugcheck 116 spôsobuje nekompatibilný,poškodený ovládač ku grafickej karte,ale aj miestne prehrievanie grafickej karty v zle vetranej skrini..pokial má grafika aktívnu funkciu hypermemory alebo turbocache,môže túto chybu vyvolať aj vadná systémová pamäť,kam hypermemory/turbocache pristupuje,takže prekontroluj najprv počítač pomocou memtest programu,pokial sa tam nenájde chyba,použi ovládače pre grafickú kartu od výrobcu grafickej karty/nie od výrobcu graf.čipu/ a zároveň prekontroluj jej zapojenie-či sa nevysunula zo zbernice,či má všetky potrebné prídavné napájcie konektory korektne zapojené a čii má vôbec pc adekvátny zdroj,ktorý utiahne celú zostavu aj s menšou rezervou....
↑ ← Odpovědět
qweasd [80.242.33.xxx], 19.03.2017 12:13
ďakujem za radu idem na to zroj je určite dobrý počítač fungoval už tak 2 roky
↑ ← Odpovědět
qweasd [80.242.33.xxx], 19.03.2017 14:52
No dobre problem je stale rovnaký ten memtest nenašiel žiadnu chybu a počitač ide stale zapnut len v safe mode a nejde nainstalovat ovladač na grafiku ani z originalneho cdčka že nemoze najst niaky driver či čo
↑ Odpovědět
Zlatý rádce lední brtník, 19.03.2017 18:51
stále předpokládám vadně / vůbec nenaistalovaný chipset driver k desce.
odkdy to dělá a co se v té době změnilo?
wunderbär
↑ ← Odpovědět
TOPlist
