Převeďte jedním klikem chráněná DVD nebo Blu-ray do svobodného MKV formátu
Včera vyšla nová beta.
Program umí jedním kliknutím převést vaše DVD nebo Blu-Ray nahrávky do MKV. Kdo zná ImgBurn nebo DVD Decrypter, určitě se zarazí na skoro stejném GUI.
www.makemkv.com
MKV formát, je svobodný a nezatížený všelijakými patenty. Přehrát umí každý normální přehrávač (windows.html). MKV formát je "kapesní" DVD. V jednom souboru můžete mít stovky video streamů, audio streamů, titulků, kapitol, textu..
Reads DVD and Blu-ray discs
Reads Blu-ray discs protected with latest versions of AACS and BD+
Preserves all video and audio tracks, including HD audio
Preserves chapters information
Preserves all meta-information (track language, audio type)
Fast conversion - converts as fast as your drive can read data.
No additional software is required for conversion or decryption.
Available for Windows, Mac OS X and Linux
Functionality to open DVD discs is free and will always stay free.
All features (including Blu-ray decryption and processing) are free during BETA.
![[sshot-t3-web.png]](http://www.makemkv.com/images/sshot-t3-web.png)
Limitations:
· MakeMKV BETA has several major restrictions. Firstly, it is time-limited -- it will stop functioning after 60 days. You can always download the latest version from makemkv.com that will reset the expiration date.
· This BETA version is limited to Windows platform only and requires computer administrator privileges to run. This is limitation of Windows SCSI application programming interface. The full version of MakeMKV will not require administrator privileges to run.· HD-DVD and Blu-ray have limited support in this version. For HD-DVD only video and subtitles tracks are supported. Only old Blu-ray titles are supported in BETA version (MKBv3 and below, no support for BD+ titles).
Dik za info
. Vyzkousim.
Mazec. Díky
Hlavně si lidi přečtěte "Limitations".
Zadny problem.
Zatím si vystačím s DVDFab, ale do budoucna pro mně zajímavá volba.
dík za tip, potřeboval jsem ripnout chráněné dvd "dívčí válka", zabral až trial dvdfab 6.
Ta nadhera za dve kila je chranena?
Jejda, to by me nenapadlo (a uz to mam doma jakysi patek).
Vyzkousel jsem to (na DVD) a funguje to.
Zvládajú to aj "kamenné" prehrávače?
Pouze ty co mají podporu MKV, takže obecně ne.
jeden z několika: index.aspx
http://www.alza.cz/popcorn-hour-a-110-media-player -divx-xvid-h-264-dvd-mp3-wma-ogg-jpeg-prehravac-us b-hdmi-1-3a-av-do-lan-d103761.htm
