SQL - prosím odladit
select StoreCards.Name, cast(documents.OrdNumber as integer),
ib_datetostring(documents.DocDate$Date,'DD.MM.YYYY '),
documents2.QUnit, documents2.ID, storeBatches.Name, StoreCards.EAN,
LogStorePositions.BarCode, StoreCards.id StoreCardId, StoreCards.Code KodSklKarty,
(select l1.storeposition_id PoziceOdkud, l2.storeposition_id PoziceKam, SC.name from logstoredocuments ld
left join logstoredocuments2 l1 on l1.parent_id=ld.id and ld.documenttype='33'
left join logstoredocuments2 l2 on l2.id=l1.masterrow_id left join storecards SC on sc.id=l1.storecard_id
where l2.storeposition_id is not null and l2.Parent_ID = '' ) from LogStoreDocuments documents left join LogStoreDocuments2 documents2 ON Documents.id=documents2.Parent_ID left join StoreCards
ON Documents2.StoreCard_ID=StoreCards.id LEFT JOIN storeBatches on documents2.StoreBatch_ID = storeBatches.ID LEFT JOIN
LogStorePositions ON LogStorePositions.ID = documents2.StorePosition_ID where Executed = 'N' and DocumentType = '33' and
documents.OrdNumber = '&A2' and PositionType = '0' order by LogStorePositions.BarCode
Hlásí:
Count of column list and variable list do not match.
Kde se tak děje prosím ?
Omlouvám se. Jedná se o počet záznamů vs. záznamy subselectu. Bez znalosti konkrétnich dat v db neřešitelné na dálku.
Admini, můžete smazat.
A to je celý příkaz?
jo
Nebo ještě jednou a lépe, kde je chyba:
LogStorePositions.BarCode, StoreCards.id StoreCardId, StoreCards.Code KodSklKarty, l1.storeposition_id PoziceOdkud, l2.storeposition_id PoziceKam
from LogStoreDocuments documents left join LogStoreDocuments2 l1 ON Documents.id=l1.Parent_ID left join StoreCards
ON l1.StoreCard_ID=StoreCards.id LEFT JOIN storeBatches on l1.StoreBatch_ID = storeBatches.ID LEFT JOIN
LogStorePositions ON LogStorePositions.ID = l1.StorePosition_ID
left join logstoredocuments2 l2 on l2.id=l1.masterrow_id left join storecards on storecards.id=l1.storecard_id
documents.OrdNumber = '2190' and PositionType = '0' order by LogStorePositions.BarCode
Psal jsi, že to bez znalosti dat neřešitelné na dálku.
Tohle už jo.
To je upgrade
Hlásí to:
Alias L1 conflict with alias in the same statement.
Píšou ti to tam. Alias L1 jsi použil vícekrát.
Kde nahradit a čím?
Nahradit ho tam, kde jsi ho použil. A libovolným jiným nepoužitým aliasem.
Tak už to funguje.
Ale přesto mám dotaz.
l2.QUnit, l2.ID, storeBatches.Name, StoreCards.EAN,
left join logstoredocuments2 l1 on l1.parent_id=documents.id and documents.documenttype='33'
LEFT JOIN LogStorePositions ON LogStorePositions.ID = l1.StorePosition_ID
documents.OrdNumber = 2198 and PositionType = '0' and l2.storeposition_id is not null
Nyní mám ve sloupečkách PoziceOdkud a PoziceKam hodnotu ID do tabulky LogStorePositions.
Jak vytáhnu zároveň v tomto dotazu i LogStorePositions.NAME v závislosti na příslušném ID, které obsahuje příslušná PoziceOdkud a PoziceKam ?
Snad jsem se vyjádřil alespoň částečně srozumitelně. Už jsem totálně unavený a nemyslí mi to. Děkuji
LogStorePositions.BarCode, StoreCards.id StoreCardId, StoreCards.Code KodSklKarty, l1.storeposition_id PoziceOdkud, l2.storeposition_id PoziceKam, p1.name, p2.name
LEFT JOIN LogStorePositions p1 ON p1.ID = l1.StorePosition_ID
LEFT JOIN LogStorePositions p2 ON p2.ID = l2.StorePosition_ID
Děkuji Wikane.
A teď se jdu konečně vyspat.
