![Zasílat nové odpovědi e-mailem Zasílat nové odpovědi e-mailem](https://static.poradna.net/images/post/action/subscribe.png)
problém s načtením jedné stránky
Dobrý den potreboval bych pomoct na mojem PC se snazim nacist stranku tera-europe.com
kde by se melo nacist neco o hre Tera a serverech a registrovani a tak misto toho se hned nacte stranka na nejake filmy ale pritom a poli s adresou je napsano adresa tera-europe.com pritom tam je tahle stranka na filmy nactena (www.onlinemoca.com) zkousel jsem to ve 4 ruznych prohlizecich a furt to same ale treba na mobilu nebo na nootebooku me to jde nacist takze bude nekde chyba v PC prosím poradte
Zdravím, v prohlížeči vymaž veškerou historii.
to nepomohlo :(
zkontroluj a kdyžtak sem pošli obsah souboru hosts.txt
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
127.0.0.1 static3.cdn.ubi.com
127.0.0.1 ubisoft-orbit.s3.amazonaws.com
127.0.0.1 onlineconfigservice.ubi.com
127.0.0.1 orbitservice.ubi.com
127.0.0.1 ubisoft-orbit-savegames.s3.amazonaws.com
213.239.204.183 www.subdomain.sls.tera-europe.de
213.239.204.183 subdomain.sls.tera-europe.de
213.239.204.183 www.account.tera-europe.com
213.239.204.183 account.tera-europe.com
213.239.204.183 www.sls.tera-europe.de
213.239.204.183 www.tera-europe.com
213.239.204.183 sls.tera-europe.de
213.239.204.183 tera-europe.com
smaž tohle
ulož, vypni prohlížeč, zapni prohlížeč a mělo by to fungovat. Pak si projeď pc na viry
furt to nefunguje :(
Snad byl ten prohlížeč opravdu ukončený a ne jenom minimalizovaný. Neuložil se ten soubor náhodou jako hosts.txt? To zjistíš, když si zapneš zobrazování přípon.
smazal jsem to v tom souboru pak jsem vypnul a zaplnul prohlizec a prosim kde se zapina zobrazovani pripon ? :)
Napiš do Google zobrazování přípon a přečti si to, asi to bude hned na prvním odkazu.
on to totiz neni hosts.txt, co?:) to je tak, kdyz se montuju cemu sam nerozumim:)
tak se podívej do toho hosts, jestli to tam není znovu
není to tam znovu
jeste bys ten pc mohl v nouzovem rezimu (pri
zapinani pc mackat zbesile F8) programem superantispyware. Je o tom clanek i s navodem dokonce tady na poradne.
taky nefunguje naslome to jeden trojan a pak enco dlasiho ale ani po tom to furt nefunguje :(
to je v kterém jazyce?
a příkaz:
...ti vypíše co?
159.253.18.161 account.tera-europe.com
Dyk to tam máš furt, tak to smaž.
tedka jsem vyplnul prohlizec smazal jsem to ulozil zapl prohlizec a nejde to furt podival jsem se znovu do toho souboru a je to tam znova
Protože se to možná uložilo jinak, či kdoví co. Zkrátka jsi to tam nesmazal. Už sis zapnul ty přípony?
takze mam tam soubor hosts bez propony tam je toto:
a pak tam mam hosts.txt a ten je prazdny
kdyz otevru soubor hosts bez pripony a ulozim tak se mi zda ze se to neulozi
Nemá atribut pouze pro čtení? Když ho ukládáš, možná se to přehodí samo. Dej "uložit jako" a zvol ten bez přípony.
ted jsem to udelal a vzdy se me to zepta ze dany soubor existuje jestli to chcu prepsat dam ano ale porad se mi zda ze se to ani neulozi pac to tam je furt
Spustit notepad jako správce a proklikat se k souboru hosts, třeba.
tedka jsem se tam proklokal a ten soubor je prazdny
soubor s txt je prazdny ale soubor bez txt tam to furt je
Ano, v tom souboru hosts se ty řádky musí smazat a potom to uložit.
JOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
tvl dikec uz to funguje jsem tu spustil pres spravce proklikal jsem se tam pak jsem dal zobrazit vsechno otevrel jsem hosts bez pripony vymazal jsem to dal ulozit a uz to tam neni a ten web se me otevrel tak jak to ma byt fakt dekuji vsem za snahu a za rady :D
To je bezva, že se to, co tu píšeme od rána za 6 hodin povedlo.![:-)](https://static.poradna.net/images/smiley/smile.gif)
kezby to bylo jen 6 hodin :) jsme to resily asi tyden :D
