Minecraft
Dobrý den chtel jsem se vas zeptat kolem Minecraftu
Protoze s nim mam problem nejde mi ho hrat kdyz se prihlasim na muj nick tak se to nacita tak jak by melo ale najednou tam vybehne sidiva tabulka a ta pise :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 8.3.13 12:50
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows XP (x86) version 5.1
Java Version: 1.7.0_15, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 459815968 bytes (438 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelForma t(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat (WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(Windo wsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java :311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 717ec033 ----------
a kdyz jsem si t prelozil na googlu tak to znamena :
co mam delat prosim poradte na email : pruchalada@seznam.cz
Děkuji
hry.poradna.net (karel)
nainstaluj si ovladače od grafiky
