Nevim kde je v css kodu chyba
projel jsem css soubor validátorem a ten mi vyhodil takovouto chybu: (asi teda spatne ukonceny <div>)
Line 157, Column 22: document type does not allow element "div" here; missing one of "object", "applet", "map", "iframe", "button", "ins", "del" start-tag
<div class="details">
The mentioned element is not allowed to appear in the context in which you've placed it; the other mentioned elements are the only ones that are both allowed there and can contain the element mentioned. This might mean that you need a containing element, or possibly that you've forgotten to close a previous element.
One possible cause for this message is that you have attempted to put a block-level element (such as "<p>" or "<table>") inside an inline element (such as "<a>", "<span>", or "<font>").
Ale jak ale at koukam jak koukam, nevidim na mem kodu nic spatne, proto vas prosim o opravu...
<!--Bar 3-->
<div class="mosaic-block bar3">
<a href="http://www.desktopped.com/featured/2010/09/multi-d isplay-setup-with-four-systems-and-a-whole-lot-of- screen-space/" target="_blank" class="mosaic-overlay">
<h4>Multi-Display Setup With Four Systems, A Wall of Screens, And 64TB Of Storage</h4>
<p>via Desktopped</p>
</div>
</a>
<a href="http://www.nonsensesociety.com/2010/12/i-am-not-hu man-portraits/" target="_blank" class="mosaic-backdrop"><img src="http://buildinternet.s3.amazonaws.com/projects/mos aic/64tb.jpg" alt="fotka1"/></a>
</div>
</div>
(misto html kod jsem napsal css kod.. ach jo)
A co se tyce vasi rady, web pak nefunfuje jak ma, tak jsem ho ani nezkousel validovat...
Mimochodem - CSS máš v pořádku: c4hl3f7 a c6nfccv
Zato HTML vykazuje vady na kráse Result: 123 Errors, 7 warning(s)
