Failed to load control "XceedZip" from XceedZip.dll
Zdravím
mám problém s programom CenKrosPlus. konkrétne keď ho chcem otvoriť mi píše chybu."Failed to load control "XceedZip" from XceedZip.dll . Your version od XceedZip.dll may be outdated. Make sure you are using the version of the control that was provided with your application."
používam Windowns XP verzia 2002 SP3
verzia programu Kros je 14.1.0.0
