Jak na linuxu přehrát ogg v "riff" kontejneru
ahoj, nejde mi v linuxu (ale ve windows ano) přehrát natož ani ve ffprobe zobrazit soubory samplů z FLStudia s příponou wav. (zkoušel jsem příponu změnit na ogg ale běz úspěchu)
ffprobe: (nechápu operation not permitted)
/tmp % ffprobe STR_Mixo_C3.wav.ogg
[wav @ 0x1222ea0] Could not find codec parameters for stream 0 (Audio: none (Og[0][0] / 0x674F), 44100 Hz, 2 channels, 128 kb/s): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
STR_Mixo_C3.wav.ogg: Operation not permittedhexdump souboru
00000000 52 49 46 46 88 76 00 00 57 41 56 45 66 6d 74 20 |RIFF.v..WAVEfmt |
00000010 1a 00 00 00 4f 67 02 00 44 ac 00 00 80 3e 00 00 |....Og..D....>..|
00000020 01 00 10 00 08 00 01 02 02 20 31 12 01 20 66 61 |......... 1.. fa|
00000030 63 74 04 00 00 00 4c 20 01 00 64 61 74 61 61 75 |ct....L ..dataau|
00000040 00 00 4f 67 67 53 00 02 00 00 00 00 00 00 00 00 |..OggS..........|
00000050 00 00 00 00 00 00 00 00 51 e5 5e 71 01 1e 01 76 |........Q.^q...v|
00000060 6f 72 62 69 73 00 00 00 00 02 44 ac 00 00 ff ff |orbis.....D.....|
00000070 ff ff 1f f4 01 00 ff ff ff ff b8 01 4f 67 67 53 |............OggS|
00000080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 |................|
00000090 00 00 29 cc 8c 5f 0c 46 ff ff ff ff ff ff ff ff |..).._.F........|
000000a0 ff ff 92 03 76 6f 72 62 69 73 20 00 00 00 58 69 |....vorbis ...Xi|
000000b0 70 68 6f 70 68 6f 72 75 73 20 6c 69 62 56 6f 72 |phophorus libVor|
000000c0 62 69 73 20 49 20 32 30 30 31 31 32 33 31 01 00 |bis I 20011231..|
000000d0 00 00 12 00 00 00 45 4e 43 4f 44 45 52 3d 76 6f |......ENCODER=vo|
000000e0 72 62 69 73 2e 61 63 6d 01 05 76 6f 72 62 69 73 |rbis.acm..vorbis|
000000f0 25 42 43 56 01 00 40 00 00 80 60 da 11 05 36 c5 |%BCV..@...`...6.|
00000100 a4 94 52 9e 71 58 2a 29 3a e5 a4 94 52 b2 c3 22 |..R.qX*):...R.."|
00000110 3b 4d ca 27 a5 94 52 4a 29 a5 7c 52 ca 18 63 8c |;M.'..RJ).|R..c.|
00000120 31 82 d0 90 55 00 00 10 00 00 41 0c 65 06 59 c9 |1...U.....A.e.Y.|
00000130 1c 17 5f 83 46 0c 75 06 59 c9 1c 17 df 7b 89 90 |.._.F.u.Y....{..|
00000130 ...nainstalované balíky
dj@none ~ % pacman -Qs ogg\|vorb
local/lib32-libogg 1.3.1-1
Ogg bitstream and framing library (32-bit)
local/lib32-libvorbis 1.3.3-1
Vorbis codec library (32-bit)
local/libkate 0.4.1-4
A karaoke and text codec for embedding in ogg
local/libogg 1.3.1-1
local/libvorbis 1.3.3-1
local/rlog 1.4-4
A flexible message logging facility for C++ programs and libraries
Chybí něco?
Mohlo by pomoct to prebalit, velmi podobne ako .ts do .ps ...
riff a ogg su rozne kontajnery. Linux rozumie len ogg kontajneru.
problém je ,že těch souborů je 1485... A dokonce je ani nerozpozná FlStudio samotné i po aplikaci Step 2, odstavce 5 odsud. Při přetáhnutí do step sequenceru se přidá nový pattern, který ovšem je prázndný
Neviem ako je to u tohoto, ale na Windowse som sa stretol aj s tym, ze stream v kontajneri bol zakodovany a len prislusna aplikacia ho vedela prehravat, aj ked to malo normalnu koncovku .wma Vychadzat treba z toho, ci to prehra Windows.
Ak ano, tak sa poprehrabuj v registri ci tam nahodou nenajdes nieco co by sa dalo pouzit (napriklad kodovaci/sifrovaci kluc)
Sakra, tohle mě štve...
Myslim, ze podstatne bude to ACM.
Najdi si tuna: help help:
How to use the Windows Audio Compression Manager
spomina sa tam tato kniznica: MSACM32.DLL
mas ju ?
Ani VLC ti to nepřehraje? Audacity s tím taky nehne? Co máš za distro? Kodeky bývají většinou v extra repositářích, protože jejich volnost použití nebývá zrovna moc košér.
Jde o tento soubor třeba(viz příloha):
file:///run/media/nona/WINDOWS/Program Files/Image-Line/FL Studio 9/Data/Projects/Used by demo projects/One Day (Funky Mix)/RD_Crash_2.wav
Zjištění: Ve windows taky žádný program (kromě fl studio)nedokáže přehrát dayný soubor (pot player, kmplayer, ffplay, wmp)
gspot 2.70 z roku 2007 ukazuje 0x674f (Ogg Vorbis 1), COdec not installed.
asi vím kde bude problém...jelikož ten soubor leží ve složce windows,
ale je to divný... soubory v system32 a syswow se nachází i ve wine složce v linuxu. pro jistotu jsem tak zkopíroval i winsxs záznamy ,ale furt to nejde. Mám Manjaro
zde je výpis na windows oddílu
ne, nejde
MPlayer Sherpya-SVN-r29355-4.5.0 (C) 2000-2009 MPlayer Team
Setting process priority: abovenormal
Cannot load bitmap font: Arial
c:\windows\fonts\arial.ttf doesn't look like a bitmap font description, ignoring.
Playing C:/Users/Villiers/Desktop/rd-crash-2.wav.
Cache fill: 0.00% (0 bytes)
Cache fill: 0.84% (17160 bytes)
ID_AUDIO_ID=0
Audio only file format detected.
ID_FILENAME=C:/Users/Villiers/Desktop/rd-crash-2.w av
ID_DEMUXER=audio
ID_AUDIO_FORMAT=26447
ID_AUDIO_BITRATE=72000
ID_AUDIO_RATE=0
ID_AUDIO_NCH=1
ID_LENGTH=1.00
ID_SEEKABLE=1
ID_CHAPTERS=0
Opening audio decoder: [acm] Win32/ACM decoders
ACM_Decoder: Unappropriate audio format
Could not load/initialize Win32/ACM audio codec (missing DLL file?).
ADecoder preinit failed :(
Loading codec DLL: 'vorbis.acm'
Can't open library vorbis.acm
ADecoder init failed :(
Cannot find codec for audio format 0x674F.
Audio: no sound
Video: no video
Exiting... (End of file)
ID_EXIT=EOF
na win vyzjisti direct show cestu u souborů co jdou- tam bude hodně soukromej sráč, co to přehrá.
