Zase mě ten gmail zlobí...
Zdravíčko, poslední dobou nemůžu odpovídat na seznam.cz/centrum.cz a ruzné yahoo.com a jiné emaily, vždy mi vyskočí po odeslání emailu, tenhle email. Nevíte někdo co s tím? Děkuji moc.
Delivery to the following recipient failed permanently:
mailer-daemon@gmail.com
Technical details of permanent failure:
The user you are trying to contact is receiving mail at a rate that prevents additional messages from being delivered. Please resend your message at a later time. If the user is able to receive mail at that time, your message will be delivered. For more information, please visit http://support.google.com/mail/bin/answer.py?answe r=6592----- Original message -----
Return-Path: <mn.animals@gmail.com>
Received-SPF: pass (google.com: domain of mn.animals@gmail.com designates 10.58.80.7 as permitted sender) client-ip=10.58.80.7
Authentication-Results: mr.google.com;
spf=pass (google.com: domain of mn.animals@gmail.com designates 10.58.80.7 as permitted sender) smtp.mail=mn.animals@gmail.com;
dkim=pass header.i=@gmail.com
X-Received: from mr.google.com ([10.58.80.7])
by 10.58.80.7 with SMTP id n7mr9461194vex.23.1376481717376 (num_hops = 1);
Wed, 14 Aug 2013 05:01:57 -0700 (PDT)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
d=gmail.com; s=20120113;
h=mime-version:in-reply-to:references:date:message -id:subject:from:to
:content-type;
bh=V7N7Gm/iWWuUqwJusvA+bcFp2TBa6dd1rIOybRoHhXk=;
b=wmhmLS1F+cwoV8Q5dWSM4ERdB2KPKmktpYpr8WW6IqNFqBAD UQ0ulmiw3i5ulbqN0e
dyN5qyMoYOwuHJupow73EHHUH02M6c/+m/nR9fviu4Sh5lB6el B4eGHhGVl++fJtMnMr
CkwQ/KaQkY1y42NmoFHMCL+REKhocF3Oj6eNLwwU2GMZ0kTHbv Qf2EsP6EbJBr35MmPf
SKRjcTHxMfKNS7Va7LrLGHRAyx4D+45k7gROoVAAbIKvUIUdP5 iSrOAF5GzBWGmx+xhf
5yRLRW9tu3+0SJ5Wmtv6dClhZL0sT6QBpOhRYrhD80OdwKfPZB roI2LO5BcWaG34FL3N
rVjw==
MIME-Version: 1.0
X-Received: by 10.58.80.7 with SMTP id n7mr9461194vex.23.1376481717372; Wed,
Received: by 10.59.0.164 with HTTP; Wed, 14 Aug 2013 05:01:57 -0700 (PDT)
In-Reply-To: <001a11c3b944e5076004e3e71ed0@google.com>
References: <CAPdyD8FyWKH2xUx8ChOe1DtzDEUmWyrWFBLuSp3uGPfairLA Uw@mail.gmail.com>
Date: Wed, 14 Aug 2013 14:01:57 +0200
Message-ID: <CAPdyD8EUCT2nR1UuRc-nHdjKNe419v1=C4L2uNpf6szEtNA0 BA@mail.gmail.com>
Subject: Re: Delivery Status Notification (Failure)
To: Mail Delivery Subsystem <mailer-daemon@googlemail.com>
Content-Type: multipart/alternative; boundary=047d7b450c6ccdcdec04e3e71f04
Jak ty maily posíláš (pošt. klient, webové rozhraní, PHPmailer)?
Možná máš počítač zaprasený viry, trojany a g-mail (a/nebo ty poštovní servery) si to už nenechali líbit. Posíláš zprávy častěji, než je zdrávo.
Jo tomuhle vůbec nerozumím, posílám klasicky email, z internetu, žádný klient nepoužívám.
Zaprasený viry ho nemám, a emaily neposílám zase nějak moc, pouze pracovní emaily. Každopádně to blbne i přítelkyni která z emailu skoro vůbec nic neposílá...
Častěji, "než je zdrávo" může znamenat i to, že se e-mail pošle třeba 3x za vteřinu/minutu (podrobnosti nevím). Kromě nějaké boty v OS nebo v prohlížeči, to může být činnost nějaké škodné. Čím jsi to kontroloval?
Tak sem se tím začal zabývat, založil si email na seznamu a u jednoho mailu mi to ukázalo, že dotyčný má plnou kapacitu.
achjo, a to vím i já...teď to víš taky...nicméně mě zaráží, že zdejší rádci vždycky začnou řešit problém nejsložitější cestou, začnou-li vůbec..
Zdejší rádci možná předpokládají, že si uživatel dokáže ohlídat, jestli si nezavalil schránku blbostma.
Heh, psal jsem, že příjemce měl plnou schránku né já, naučte se číst, když už děláte chytrolína.
jenže s tím to jaksi nesouvisí. Vysvětlení je jasně a jednoznačně popsáno v mailu, nechápu, co řešíš.
Ty si zase pro změnu nasaď cvikr a podívej se, na kterou odpověď jsem reagoval.
Tak si sám aj odpovedal - potom ty si chytrolín. Ak je plná schránka, ďalšie e-maily tam nepribudnú, pokiaľ sa schránka neuvoľní. Takže chyba je na strane príjemcu. Potom ťa G-mail nemôže "zlobit", pretože robí to, čo má.
Po 8 letech to je už skoro jedno, kdo je chytrolín.
