Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Ovladače
Minecraft-
Dobrý den :) Tento dotaz vlastně není přimo k Minecraftu :) Když spustím hru.. hra mi napíše -
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 24.8.13 21:28
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.7.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 459109728 bytes (437 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelForma t(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat (WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(Windo wsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java :311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:235)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT e65a7f6f ----------
Vím že je to problém s ovladačem, ale pokoušel jsem se nainstalovat ty které jsem nešel.. a nepomohlo :)
Byl bych vám velmi vděčný kdyby jste mi někdo napsal odkaz na grafický ovladač který mi chybí =) Mám Windows 7 - 32 bit. Grafika- Radeon X1650 Series
Děkuju moc ;)
Zkus stáhnout a nainstalovat ovladače co ti napíšu v tom pořadí co to bude. Ovladače stáhni z webu v…
albru123 24.08.2013 22:12
albru123
X grafiky nejsou integrované, byly to první grafiky pro PCI Express.
Wikan 24.08.2013 22:13
Aha, ok. Já mám ale X1250 integrovanou. Další nové info :-D
albru123 24.08.2013 22:20
albru123
Podle me ta tvoje grafika nepodporuje stupen Open GL, tahle grafika podporuje jen verzi 2.0, ( http:… poslední
Schizo 24.08.2013 22:36
Schizo
Zkus stáhnout a nainstalovat ovladače co ti napíšu v tom pořadí co to bude. Ovladače stáhni z webu výrobce základní desky (X grafiky jsou myslím integrované, takže proto z webu výrobce MB).
1. Chipset driver
2. ATI VGA Driver
