Nespusti sa OS
DObry den praje,
mam problem s mojim nb presnejsie ide o lenovo thinkpad t510i. Nenabhen mi os. Prv naskoci nejaka chyba a potom ked kliknem na windows start normaly lebo ako to uz je tak mi zacne nacitavat no po chvili mi to padne do modrej obrazovky s chybami.
zacina to takto ...problem has been detected and windows has been shutdown to prevent damage to your computer
nemam instalacne cd od os a ked dam recovery tak pri poslednom kliknuti next by mi uz malo zacat robit recovery no mne vyskoci tabulka, ze sa musi restartovat a ze po restarete sa vrati do tohto modu no nevrati sa lebo ked sa restartne naskoci zase chybova hlaska . Windows failed to start. A recent hardware or software change might be the cause. To fix the problem ... status:0xc000000e
info: The boot selection failed bacause a required device is inaccessible
A tahle chyba je docela dulezita k identifikaci problemu. Popis "nejaka chyba" nepomuze
Co jsi delal pred tim, nez to zacalo zlobit? Co jsi instaloval?
V rezimu nouze to naskoci? To je tam, kde zapinas spusteni systemu normalne
ta modra obrazovka rychlo naskoci a rachlo zmizne ... nic nebolo instalovane ... nejake dokumenty robene..facebook... a nudzovy rezim nejde tiez ! ani cez prikazovy riadok
Super, čili po zapnutí PC mačkejte F8 a v nabídce, co se zobrazí, zvolte možnost "Zakázat automatické restartování při selhání" (je cca 3. odspod).
Chyba znie takto: A problem has been detected and windows has benn shut down to prevent damage to your computer.
A proces or thread crucial to system operation has unexpectedly exited or been terminated.
If this is the first time you ve seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
CHeck to make sure any new hardware or software is properly instaled. If this is new a installation, ask your hardware or soft. manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or soft. Disable BIOS memory options such as caching or shadowing. If you need to sue safe mode to remove or disable components, restart your pc, press f8 to select advanced startup options, and then select safe mode.
Tecnical information:***STOP:0x000000F4 (0x00000003,0x820E9530,0x820E969C,0x8306CEA0)
Collecting data for crash dump...
Initializing disk for crash dump ....
Beginning dump of physical memory.
Dumping physical memory dump complete.
Contact your system admin ....
