Minidump
Nedávno mi začala při spuštění PC modrá smrt. Debugging Tools mi nějak nefunguje a tak bych potřeboval zjistit v čem je problém. Blue Screen naskočí pokaždé až na nouzový režim. Win jsem ještě nezkoušel přeinstalovat. Odkaz na Minidump : 082513-32448-01-dmp
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
FAULTING_MODULE: fffff80003a13000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4f7e4294
FAULTING_IP:
atikmpag+8768
fffff880`044f0768 4055 push rbp
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`05fb4a58 fffff880`05562054 : 00000000`00000116 fffffa80`07e9c4e0 fffff880`044f0768 00000000`00000000 : nt+0x75c00
fffff880`05fb4a60 00000000`00000116 : fffffa80`07e9c4e0 fffff880`044f0768 00000000`00000000 00000000`00000002 : dxgkrnl+0x5d054
fffff880`05fb4a68 fffffa80`07e9c4e0 : fffff880`044f0768 00000000`00000000 00000000`00000002 00000000`00000000 : 0x116
fffff880`05fb4a70 fffff880`044f0768 : 00000000`00000000 00000000`00000002 00000000`00000000 00000000`00000000 : 0xfffffa80`07e9c4e0
fffff880`05fb4a78 00000000`00000000 : 00000000`00000002 00000000`00000000 00000000`00000000 fffff880`05561d5e : atikmpag+0x8768
STACK_COMMAND: kb
FOLLOWUP_IP:
atikmpag+8768
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: atikmpag+8768
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
2: kd> !analyze -v
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8007e9c4e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff880044f0768, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Obrázek na ulozto?!...kravina..aby se každý koukl na jeden obrázek a musel si to stáhnout,na to se ti vybodnou.
Vložení obrázku na poradnu:KLIK
to je dump, ne obrázek.
Už to vidím,když jsi byl ochoten to zkopčit ,ale i to se dá sem vložit přímo.
má to mega, to by myslím se sem dalo protlačit.
To není bmp, ale dmp :)
Podle minidumpu to vypadá na chybu DirectX dxgkrnl.sys. Zkus to přeinstalovat. Ovladače pro jistotu taky.
hledáš důsledek, ne příčinu patrně. chybuje ovladač atiny, který způsobí chybu v jádru (jak jinak) v rozhraní directx.
Proto jsem psal, aby přeinstaloval raději oboje. Ono taky záleží na tom, čím se na ten minidump koukne.
