Doopravdy to píše co? Jestli jde o sw problém, jde udělat zálohu disku třeba v jiném počítači nebo ty Windows opravit.
toto mi pise
Windows has encountered a problem comunicating with a device connected to your computer.
This error can be caused by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive that is faling. Make sure any removable storage is properly connected and them restart your computer.
If you continue to receive this error message, contact the hardware manufacturer.
Status: 0xc00000e9
Info: An unexpected I/O error has occurred.
A ani po restartovani neide... zase toto iste naskoci
Máš nastaveno bootování z HDD s odpojena všechna externí zařízení?
Nabootuj ubuntu z USB sticku a pozri sa na ten disk ci je viditelny a ci sa na neho da pristupovat
nemam nic pripojene, ziadne zariadenia... aj ked skusam cez safe mode stale ma hodi na toto iste
A to je konec... Co je to Ubuntu?
to neviem ani ja... zajtra to dam kamosovi co sa v tom vyzna..... inac dakujem za reakcie ;)
Ubuntu je operační systém založený na Linuxu.
z_flash_disku
