Nemoznost otevirani priloh TIF v OUTLOOK 2003
Zdravim,
nejdou mi otevrit prilohy TIF v Outlok 2003 (pres Exchange server).
Pri pokusu o otevreni to hodi hlasku "Soubor TIF nelze vytvorit. Klepenete pravym tl. mysi na slozku ve ktere chcete vytvorit soubor, v mistni nabidce vyberte prikaz Vlastnosti a zkontrolujte opravneni k pristupu do slozky".
Standardne obrazky oteviram v "Prohlizeci obrazku a faxu"
Pres Outlook web access to jde bez problemu a jine prilohy (DOC, PDF atd) jdou otevrit z outlooku 2003 taky.
Do Document and settings - user - local settings - temp pravo zapisovani samozrejme je.
OP system: XP PROF CZ.
A pri pokusu o ulozeni souboru zase Outlook rve: Aplikace outlook nemohla soubor ulozit. (kamkoliv)
Nasel jsem v googlu toto: I found the following which helped me with the exact same poblem that you are having.
Microsoft Outlook uses a temporary folder to save and open the attachments. By default that folder is:
C:\Documents and Settings\%USER_NAME%\Local Settings\Temporary Internet Files\OLK#\ (where # is a random number)
Some of the latest security updates for Windows 2000 and XP are preventing folders to be created in that folder. The solution is to use the regular TEMP folder.
1. Using REGEDIT.EXE locate the following key:
My Computer\HKEY_CURRENT_USER\Software\Microsoft\Offi ce\10.0\Security
Note: Depending on your version you may have to modify that path after the "Office" key. You may have folders 8.0, 9.0, 10.0, 11.0, go the highest number. This is probably the version that you use.
2. Modify the Key "OutlookSecureTempFolder", by replacing "Temporary Internet Files" with "Temp". For example:
OLD VALUE: C:\Documents and Settings\kamen\Local Settings\Temporary Internet Files\OLK177\ (you may have different number than 177)
NEW VALUE: C:\Documents and Settings\kamen\Local Settings\Temp\OLK177\
3. Restart Microsoft Outlook.
Hope it helps you.
Jdu to vyzkouset
OK tak to funguje..
