USB bluetooth
Nazdar, zkoušel jsem připojit nějaký BT USB adapter Gellink, ale nejsem si jistý, jestli není rozbitý.
Dá se něco vyčíst z dmesg?
609.795392] usbhid 5-2:1.3: can't add hid device: -110
[ 609.795447] usbhid: probe of 5-2:1.3 failed with error -110
[ 609.796883] Bluetooth: hci1 urb ffff880041e36480 submission failed (22)
[ 633.343486] usb 5-2: USB disconnect, device number 6
lsusb
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
|__ Port 2: Dev 8, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 2: Dev 8, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 2: Dev 8, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 8, If 3, Class=Human Interface Device, Driver=, 12M
sudo lsusb -s 5:8
Bus 005 Device 008: ID 0c10:0000 (žádné jméno!)
příkaz sudo lsusb -s 5:8 -v
trvá dlouho
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0c10
idProduct 0x0000
bcdDevice 20.05
iManufacturer 1 (error)
iProduct 2 (error)
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 227
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 50mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 60
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2 Mouse
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
wDescriptorLength 72
^[[A ...
Nevím, možná by to prověřili, kdyby si to brali do kosmické stanice, ale jinak v tom nevidím šanci. Navíc poštovné do USA by bylo drahé.
No nic, prověřil jsem to ve Windows, kde to bluetooth nainstalovalo, i přes to ,že to našlo asi jen ůlku ovladačů, tak to šlape. Zřejmě nějaký bordel v linuxu.
