Scientific Linux Test Page
Dobrý den, mám problém s přístupem na webové fórum. Problém se ukazoval nejprve na prohlížeči opera, tak jsem přešel na chrome, nyní se oběvuje i na chromu. Po zadání url naskočí tato hláška:
This page is used to test the proper operation of the Apache HTTP server after it has been installed. If you can read this page, it means that the Apache HTTP server installed at this site is working properly.
If you are a member of the general public:
The fact that you are seeing this page indicates that the website you just visited is either experiencing problems, or is undergoing routine maintenance.
If you would like to let the administrators of this website know that you've seen this page instead of the page you expected, you should send them e-mail. In general, mail sent to the name "webmaster" and directed to the website's domain should reach the appropriate person.
For example, if you experienced problems while visiting www.example.com, you should send e-mail to "webmaster@example.com".
For information on Scientific Linux, please visit the Scientific Linux website.
If you are the website administrator:
You may now add content to the directory /var/www/html/. Note that until you do so, people visiting your website will see this page, and not your content. To prevent this page from ever being used, follow the instructions in the file /etc/httpd/conf.d/welcome.conf.
You are free to use the image below on web sites powered by the Apache HTTP Server:
[ Powered by Apache ]
Ale na jiném počítači, v jiné síti se na forum dostanu normálně.
Předem díky za odpovědi.
opera má snad stejné jádro jako chromák. zkus jiný prohlížeč.
Bohužel problém se vyskytuje i při použití IE. Díky.
Toto nemoze robit jadro, toto je hlaska Apacha, ktory ju danemu pc zobrazi z neznamych dovodov. Kedze nevidime do konfiguracie Aoacha a danej domeny neda sa povedat, kde je problem.
Edit: Napadla ma jedna vec este, je mozne, ze regnute nie je domen aj s www, takze zadavas vsade domenu uplne rovnako? Nie je to raz, ze www.domena.sk a u seba zadavas domena.sk napriklad? Dalsia vec je, ze mozno dana domena nebezi na http, ale len https, takze nemas na tom inom pocitaci stranku zobrazenu cez https a nie cez http? Apache moze byt nastaveny tak, aby domenu zobrazoval len urcitemu ip rozsahu, takze je dobre skusat to z rovnakej siete na 2 pc.
Niekde musi byt medzi tymi pc rozdiel.
