irql_not_less_or_equal error
Dobrý den, mám vcelku velký problém s irql_not_less_or_equal. Stalo se to potom, co jsem chtěl aktualizovat ovlaače Nvidie a proces se zasekl ve stádiu akorát po odinstalování starých ovladačů a nové se nenainstalovaly a kdykoliv se pokusím o instalaci (klidně starších ovladačů) vždy naskočí bluescreen a irql_not_less_or_equal error.
Mám notebook: Windows 8.1 (legální)
i5-4200m
Nvidia GT750m
4GB RAM
K příspěvku připojuji soubory, které se týkají problému.
Tady je výpis problému a děkuji všem za pomoc.
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Tue 27. 5. 2014 4:43:30 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052714-25656-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x153FA0)
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF8006E072DCF)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm!nvDumpConfig+0x276440)
file path: C:\WINDOWS\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 327.02
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 327.02
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 327.02 , NVIDIA Corporation).
Google query: NVIDIA Corporation IRQL_NOT_LESS_OR_EQUAL
On Tue 27. 5. 2014 4:00:45 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052714-24578-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF802BE2F5DCF)
On Tue 27. 5. 2014 2:54:17 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052714-24437-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF80081880DCF)
On Mon 26. 5. 2014 20:30:57 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052614-24656-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF8022EA80DCF)
On Mon 26. 5. 2014 19:28:01 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052614-22890-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF80035C80DCF)
typicky grafika - w8.1 je nekompatibilní prasečí šmejd, jsi tu asi dvěstěpadesátý.
no dyť.
obnov tovární nastavení (přijdeš o data).
s nesmyslnými updaty notebukových ovladačů počkej až na windows 9.
