Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailemVyřešeno Vyskakovací reklamy
Zdravím , mám problém s vyskakovacími reklamami mám je v internetu(chrome,opera,atd...) i ve steamu. Odkazy v textu reklamy na profilu hráče steamu. Něco jsem si pročetl a zkusil jsem Adwcleaner asi 5x nepomohl, poté spyware terminatore něco našel ale stejně nic poté malwarebytes opět nic.
Prikládám report z Adwcleaner jestli pomůže
# AdwCleaner v3.212 - Report created 05/06/2014 at 19:41:09
# Updated 05/06/2014 by Xplode
# Operating System : Windows 7 Professional Service Pack 1 (64 bits)
# Username : Jirka - JA-HP
# Running from : C:\Users\Jirka\Desktop\adwcleaner_3.212.exe
# Option : Scan
***** [ Services ] *****
***** [ Files / Folders ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.17041
AdwCleaner[R0].txt - [26059 octets] - [30/03/2014 17:25:01]
AdwCleaner[R10].txt - [1983 octets] - [05/06/2014 19:13:47]
AdwCleaner[R11].txt - [623 octets] - [05/06/2014 19:41:09]
AdwCleaner[R1].txt - [11187 octets] - [08/04/2014 18:26:42]
AdwCleaner[R2].txt - [4901 octets] - [28/05/2014 18:42:53]
AdwCleaner[R3].txt - [1540 octets] - [28/05/2014 18:53:45]
AdwCleaner[R4].txt - [1660 octets] - [28/05/2014 19:03:46]
AdwCleaner[R5].txt - [1780 octets] - [29/05/2014 17:52:57]
AdwCleaner[R6].txt - [1900 octets] - [29/05/2014 18:38:05]
AdwCleaner[R7].txt - [3066 octets] - [29/05/2014 19:11:24]
AdwCleaner[R8].txt - [2140 octets] - [30/05/2014 14:18:58]
AdwCleaner[R9].txt - [1772 octets] - [30/05/2014 17:37:01]
AdwCleaner[S0].txt - [24134 octets] - [30/03/2014 17:26:09]
AdwCleaner[S1].txt - [11478 octets] - [08/04/2014 18:27:56]
AdwCleaner[S2].txt - [5042 octets] - [28/05/2014 18:43:52]
AdwCleaner[S3].txt - [1603 octets] - [28/05/2014 18:54:43]
AdwCleaner[S4].txt - [1723 octets] - [28/05/2014 19:05:29]
AdwCleaner[S5].txt - [1843 octets] - [29/05/2014 17:54:09]
AdwCleaner[S6].txt - [1963 octets] - [29/05/2014 18:41:44]
AdwCleaner[S7].txt - [3108 octets] - [29/05/2014 19:12:45]
AdwCleaner[S8].txt - [2203 octets] - [30/05/2014 14:20:17]
AdwCleaner[S9].txt - [2048 octets] - [05/06/2014 19:15:57]
########## EOF - C:\AdwCleaner\AdwCleaner[R11].txt - [1826 octets] ##########
Stahni program Adblock doplněk prohližeče.
jezekhifi 05.06.2014 19:53
jezekhifi
Uz se stalo u prohlížeče to blokuje reklamy ale kontextová reklama je furt. Ve steamu jsou vyskakova…
George123 05.06.2014 20:00
George123
Jedině co mužu doporučit je adblock+mozila a funguje to skvěle. Mě vyskakovaly rovnou okna s reklamo…
jezekhifi 05.06.2014 20:04
jezekhifi
Ty si fakt pripad (viry riesit adblockom a povazovat to za "vyriesene") nech si to odviri a pozakazu…
MM.. 05.06.2014 20:05
Já se bavím o tom že v minulosti mě vyskakovali okna (to zaleži kde surfuješ) klidně deset naráz a p…
jezekhifi 05.06.2014 20:21
jezekhifi
Ja kludne surfujem aj v "deme dál" a ziaden antivirak nepotrebujem. Otazka stoji tak ze ci dotazova…
MM.. 05.06.2014 20:25
normální člověk si neinstaluje viry, spyware, adware. normální člověk na takto zahnojený pc nepoštve…
lední brtník 05.06.2014 20:58
Hluboce se mýlíš. Normální člověk používá počítač jako každý nástroj ve víře, že mu nikdo úmyslně ne…
Henessy 05.06.2014 22:14
Henessy
Normální člověk sice před tankováním nedělá chemický rozbor, ale potom taky nemá potřebu ostatním ra…
karel 05.06.2014 22:25
:-D:-D
Henessy 05.06.2014 22:39
Henessy
Pouzivanim PC nechytis ziaden vir. Pouzivanie znamena spustit firefox alebo Word alebo prehravac a p…
MM.. 06.06.2014 00:43
Napísali ti to už dvaja, ale dementnú radu že "použi Adblock a všetko bude fajn" som tu už videl od…
los 05.06.2014 21:38
los
V tom reporte neni nic. Urob log z hijackthis a vloz ho sem.
MM.. 05.06.2014 19:58
tady
George123 05.06.2014 20:31
George123
C:\Users\Jirka\AppData\Roaming\Seznam.cz\bin\sznde sktop.exe odinstalit (seznam software) O4 - HKLM…
MM.. 05.06.2014 20:52
Nejaký podrobnější popis jak to mam smazat. Ten seznam jsem už odinstaloval a ten server proxy jsem…
George123 06.06.2014 09:31
George123
Nabootujes Windows v nudzovom rezime. Povolis si zobrazovanie skrytych a systemovych suborov (ovl.pa…
MM.. 06.06.2014 09:52
A subor hosts si otvoris textovym editorom a zmazes riadky vsetky okrem 2 riadkov ktore som pisal.
MM.. 06.06.2014 09:53
Děkuji už mam pokoj :D poslední
George123 06.06.2014 12:19
George123
A potom jak to vsetko vycistis tak si v ovl.panley-moznosti internetu nastav proxy na ziadny, lebo t…
MM.. 05.06.2014 21:02
Zkus pohledat v počítači Pirrit, měl by být i doplněk v IE a dej vědět
Henessy 05.06.2014 21:57
Henessy
stáhni se www.malwarebytes.org a projeď počítač.
Henessy 05.06.2014 22:22
Henessy
Ať spustí GMER. A jinak sice adblock neřeší tento problém, ale i tak je jeho použití nutnost k tomu,…
kurare 05.06.2014 22:50
kurare
no, nedávno tu byl nešťastník s logem z gmeru a zaspywarován. čili fak nemá smysl lidem každý měsíc…
lední brtník 06.06.2014 00:21
Já se bavím o tom že v minulosti mě vyskakovali okna (to zaleži kde surfuješ) klidně deset naráz a po instalaci adblocku je pokoj. Ne že to zastaví viry. Ale zastaví to okno s virem. Pokud surfuješ na seznamu atd. tak to nepotřebuješ, my co deme dál tak to je potřeba mět adblock a antivirák.
Otazka stoji tak ze ci dotazovatl vidi len reklamy ktore na tom webe maju skutocne byt (potom nema ziaden problem), alebo ci vidi aj nieco navyse co na tom webe vskutocnosti neni (potom ma zavireny PC).
Ja neviem co presne vidi, preto som chcel aspon log z hijackthis.
Hluboce se mýlíš. Normální člověk používá počítač jako každý nástroj ve víře, že mu nikdo úmyslně neublíží. Ty taky když jdeš k pumpě na benzín, taky před tankováním neděláš chemický rozbor a když si dáš v hospodě štamprli, tak věříš, že neoslepneš.
Osvěta je sice dostatečná, ale často při instalaci programu jsou v roletce skryty různá povolení, lišty a další. Ne každý pohříchu vládne angličtinou a pak se diví, cože se mu objevilo v počítači. Troufám si tvrdit, že je mnoho oborů, v kterých dokážu udělat z tebe nesvéprávného retarda a přesto i já jsem bojoval s reklamou.
Na této poradně je krásné to, že jsou zde lidé, kteří trpělivě radí a vysvětlují a to i po několikáté. Jednakovo je to hezký pocit, že mohu někomu pomoci, druhákovo si pohoním své Ego.
Jelikož často dobře radíš, mám zato, že tvá dnešní reakce je zapříčiněna třeba tím, že jsi si dlouho "nevrzl".:-D:-D
Normální člověk sice před tankováním nedělá chemický rozbor, ale potom taky nemá potřebu ostatním radit, jak správně postupovat u čerpací stanice. Ta rada o použití Adblocku po zavirování byla opravdu idiotská. To už rovnou stačí do monitoru praštit kladivem, potom ta vyskakující okna neuvidí taky.
Pouzivanim PC nechytis ziaden vir. Pouzivanie znamena spustit firefox alebo Word alebo prehravac a pouzivat ho. (schvalne som nevymenoval IE :)
Do auta si nikto neinstaluje do motora vselijake zazracne tunice, ani tam netankuje kradnuty okrekovany benzin od rumuna zadarmo, to by mu na displayi auta tiz vyskakovali take reklamy na servis potom ze az :-D Ale za ten benzin si zaplati a ma garantovane ze je cisty. Stejne je to u PC a software(=benzin). Preco sa ludia nespravaju k PC stejne jak k autu?
A instalaciou normalneho freeware z webu vyrobcov si tiz nezaviris PC, ano mozu tam byt rozne doplnky ktore sa ale daju normalne odinstalovat, ale ne viry.
Napísali ti to už dvaja, ale dementnú radu že "použi Adblock a všetko bude fajn" som tu už videl od rôznych ľudí niekoľkokrát, takže to sem napíšem pre istotu zvýraznene: Adblock nie je riešenie. Síce potom nemusíš vidieť reklamy, ale stále máš vo svojom počítači nainštalovaný škodlivý softvér, ktorý si môže robiť s tvojím počítačom čokoľvek. A k tomu falošnému pocitu sucha a istoty z antiviráku už nepíšem radšej nič.
O4 - HKLM\..\Run: [mncyycvfhSrv] C:\windows\system32\mncyycvfh.vbe
vir
C:\Users\Jirka\AppData\Local\ffefeefc7faf02bc7e5eb cddd5d4955d\eb6b59bb0e895bd.exe
vir
O23 - Service: 1386798866e005b.exe - Unknown owner - C:\Users\Jirka\AppData\Local\ffefeefc7faf02bc7e5eb cddd5d4955d\1386798866e005b.exe
vir
subor hosts je zavireny (skopirovat cisty, viz google alebo zmazat vsetky riadky okrem 127.0.0.1 a ::1)
Viry premazat tak ze nabootujes z nejakeho ineho media alebo skusit v nudzovom rezime mazat
