Spuštěni grafickeho rozhraní v linuxu přes putty.
Zdravím.
Když mi linux najede jen do terminalu.
Jde přes putty spustit graficke rozhraní (startx)?
V helpu je že mohu spustit jako root konfigurační soubor.
Nejde to.
pi@raspberrypi ~ $ startx
X.Org X Server 1.12.4
Release Date: 2012-08-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
Current Operating System: Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0xe bcm2708.serial=0x87c5bdf6 smsc95xx.macaddr=B8:27:EB:C5:BD:F6 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Build Date: 18 December 2013 05:20:52PM
xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.29.3
Before reporting problems, check wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 9 03:13:07 2014
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
FATAL: Module g2d_23 not found.
^Cxinit: connection to X server lostwaiting for X server to shut down Server terminated successfully (0). Closing log file.
xinit: unexpected signal 2
pi@raspberrypi ~ $ sudo bash
root@raspberrypi:/home/pi# X-configure
bash: X-configure: command not found
zacal bych vyresenim tohohle:
