ako stiahnut mp3 z tejto stranky
Prosim mohli bz ste mi poradit ako stiahnut mp3 zo stranky www.q-dance.nl sekcia music/livesets,sety idu cez quicktime plugin.Uz som stahoval davnejsie tak ze som mal od niekoho linku viz.bold,a tu som otvoril cez winmedia player a dal save as,a fungovalo to ,skusal som aj teraz,a nic.Dakujem za kazdu radu,tu je zdrojak.
<div class="p122_topmiddle">
<span class="p124_title">Livesets</span><br /><br /><span class="p124_subtitle">Live sets van X-Qlusive Holland vs. Italy Main </span><br /><br /><table class="p124_resulttable"><tr><th>Titel</th><th>Fee st</th><th width="80">Liveset</th></tr><tr><td>Deepack vs. Activator @ X-Qlusive Holland vs Italy</td><td>X-Qlusive Holland vs. Italy</td><td align="right" nowrap>
<script>embedQuicktimeMovie("100","16","images/12_ listenicoon_border.jpg","","<http://downloads.q-dance.nl/uppedfiles/sounds/lives ets/X-Qlusive - Holland vs Italy/Main/X-Q_Hol vs Ita_Main_03_Deepack_Activator.mp3> E<scale=tofit>","myself","tofit","false","false"," true");</script>
<a href="javascript:open_win('http://downloads.q-dance.nl/uppedfiles/sounds/lives ets/X-Qlusive - Holland vs Italy/Main/X-Q_Hol vs Ita_Main_03_Deepack_Activator.mp3');"><img src="images/12_popup_icon.jpg" border="0" alt="Luister in popup window"></a>
</td></tr>
Změna kategorie, původně: Tipy, triky (host)
Máš tam přímo URL adresu....
Tak ji hodíš do nějakýho download manageru a je to. Nebo kde je problém?
skusal som to skopirovat do flashgetu a nejde
Skus to skopirovat (od "http"... az po ".mp3") normalne hore do adresneho riadku prehliadaca. Co sa stane? Co to vypise?
Ale kopiruj to z toho zdrojaku stranky a nie odtialto, kedze si to nevlozil ako kod, tak sa tam pridali medzery (ochrana proti dlhym riadkom).
Forbidden
You don't have permission to access /uppedfiles/sounds/livesets/X-Qlusive - Holland vs Italy/Main/X-Q_Hol vs Ita_Main_03_Deepack_Activator.mp3 on this server.
zakaz,nemam pristup,neda sa to nejak obist,kedze spustit to ide,nenacitava sa to niekde do pamate,ked to spusta???
Musis najst v zdrojaku aj funkciu (script) open_win, ze co robi.
... najlepsie aj funkciu embedQuicktimeMovie.
Ak to je z nejakeho CD tak nepouzivaj nelegalne kopie a chod si to kupit, nelegalne kopirovanie tu nepodporujeme
Když vše selže, nastupuje Audacity (record/what u hear) či Total Recorder a online záznam...
: je to driver před zvukovkou).
Některé zvukovky ovšem funkci "What U Hear" nepodporují; co vím, tak Creative Audigy_cokoliv jo. Total Recorder (shareware) by měl fungovat vždy (opravdu hodně laicky
Tak to musi spustit cez to php ze co mu z toho vyleze, ja by som si na to urobil vlastne html a klikol na save-as, a (mozno) sa to ulozi ako html a bude z toho nieco vidno ze co sa deje potom dalej, alebo to bude stacit premenovat na spravnu priponu, alebo to vobec nejde.
