Problém se spustenim Fifa 15 demo
Po spuseni hry Fifa 15 demo na me vyskoci následujici:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at DXHelper.DisplayInfo.InitDisplayModeList()
at DXHelper.DisplayInfo..ctor()
at fifasetup_csharp.Settings.CreateSettingsForAdapter ()
at fifasetup_csharp.StartingForm.PlayButton_Click(Obj ect sender, EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0. 30319/mscorlib.dll
fifaconfig
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Origin%20Games/ FIFA%2015%20DEMO/fifasetup/fifaconfig.exe
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e0 89/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/Sys tem.Drawing.dll
DXHelper
Assembly Version: 1.0.5318.28514
CodeBase: file:///C:/Program%20Files%20(x86)/Origin%20Games/ FIFA%2015%20DEMO/fifasetup/DXHelper.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Acce ssibility.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Core/v4.0_4.0.0.0__b77a5c561934e089/System .Core.dll
fifaconfig.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Origin%20Games/ FIFA%2015%20DEMO/fifasetup/cs-CZ/fifaconfig.resour ces.DLL
mscorlib.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /mscorlib.resources/v4.0_4.0.0.0_cs_b77a5c561934e0 89/mscorlib.resources.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System. Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Co s tím??
"Fifa 15 demo" není hardware, nýbrž hra.
Hry se řeší na herní poradně. (Kurt)
