Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Blue Screen
Dobrý den.
Nedávno jsem měnil grafickou kartu. Zhruba měsíc všechno běželo v pořádku a nyní se mi objevila modrá smrt dvakrát do týdne. Naposledy se mi to stalo včera při hraní Call of Duty 4 zhruba po půl hodině hraní. Po restartu se mi rozběhl ventilátor v gpu na 100% a karta byla dost zahřátá. Takže nejspíš se při zatěži zahřála a ventilátor běžel nejspíš pořád na stejné otáčky tudíž se nejspíš neuchladila a proto modrá smrt.
Zde je výpis modrých smrtí z WhoCrashed:
On Sat 4.10.2014 0:00:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100414-23649-01.dmp
This was probably caused by the following module: atikmpag.sys (atikmpag+0xB038)
Bugcheck code: 0x116 (0xFFFFFA800690B010, 0xFFFFF8800400B038, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\atikmpag.sys
product: AMD driver
company: Advanced Micro Devices, Inc.
description: AMD multi-vendor Miniport Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.).
Google query: atikmpag.sys Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrResetFromTimeout+0x214)
file path: C:\Windows\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Tue 30.9.2014 16:51:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\093014-25537-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0xC7DBB)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800F0CCDBB, 0xFFFFF88003D3B368, 0xFFFFF88003D3ABC0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: atikmdag.sys Advanced Micro Devices, Inc. SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Jak bych to mohl podle vás vyřešit?
teplotu karty si snad pohlídat umíš. zato nepíšeš nic o tom, jak jsi odinstaloval staré ovladače. je…
lední brtník 04.10.2014 17:47
No po výměně grafické karty jsem přeinstaloval ovladače grafické karty a všechno běželo v pořádku. P…
Winc 04.10.2014 20:15
Winc
takže o teplotě nic, starý ovladač zůstal v pc nedotčen, pořadí instalace jistě nevíš a o zdroji nic…
lední brtník 04.10.2014 20:19
A co chceš vědět o zdroji? Napsal jsem že mám Seasonic SS-500ET. Udělal jsem teď test ve FurMarku a…
Winc 04.10.2014 20:43
Winc
typ zdroje mi v tom dlouhém textu i teď unikl. jestli tam někde je, tak sorry. nepíšeš typ staré gr…
lední brtník 04.10.2014 20:54
Před tím tam byla EAH2900XT a teď EAH5870. Kdybych tam měl nVidiu tak by mě ani nenapadlo neodinstal…
Winc 04.10.2014 20:58
Winc
sám vidíš, jak obtížně se v tomto threadu z tebe páčí informace - a to je ten lepší případ. mnohé tv… poslední
lední brtník 04.10.2014 21:51
Byť Tebou, tak si dám repete - nová čistá inštalácia OS, následne ovládače (začneš chipsetom)... Asp…
pme 04.10.2014 20:22
pme
Nejspíš asi ano. Jen nevím co se u toho novýmu přiučím. :-D Pokaždý prvně instaluju MB ale tentokrát…
Winc 04.10.2014 20:45
Winc
tentokrát je docela možný že jsem prvně udělal opak. :-D Opakovani "Matka moudrosti" ;-)
dennyB 04.10.2014 20:52
dennyB
zato nepíšeš nic o tom, jak jsi odinstaloval staré ovladače. jestli byl instalován driver chipsetu hned po instalaci windows, ještě před grafikou.
pokud to padá až při výkonové zátěži, mělo by tu být něco o napájecím zdroji.
No po výměně grafické karty jsem přeinstaloval ovladače grafické karty a všechno běželo v pořádku. Potom jsem kupoval ještě HDD a dělal jsem komplet reinstalaci a udělalo to až po nové instalaci OS. Zdroj mám Seasonic SS-500ET. Ovladač chipsetu jsem instaloval mám dojem před grafickou kartou...ale přiznám se že jistě to nevím. Teplotu si uhlídat umím, jenže když jsem hrál tak vubec nebylo slyšet že by se nějak zvýšily automaticky otáčky.
A co chceš vědět o zdroji? Napsal jsem že mám Seasonic SS-500ET. Udělal jsem teď test ve FurMarku a teplota se ustálí na 80°C a ventilátor se automaticky zvýšlil z 28% na 33%. A nechápu jak to myslíš, že zůstal starý ovladač v PC nedotčen. :-D
Před tím tam byla EAH2900XT a teď EAH5870. Kdybych tam měl nVidiu tak by mě ani nenapadlo neodinstalovat drivery od ní.
samotné pořadí chipset - grafika zůstane až do nové instalace tajemstvím.
Nevím co tímto myslíš.
mnohé tvé minulé nekonečné dotazy jsou jen snůškou nechápavostí. já to proto beru tak, že u tebe nejde ničemu věřit a na nic spoléhat.
nainstaluj to korektně znovu a filosofickými otázkami slepice-vejce-ovladač grafiky se netrap.
Byť Tebou, tak si dám repete - nová čistá inštalácia OS, následne ovládače (začneš chipsetom)... Aspoň sa niečo naučíš. :-)
Nejspíš asi ano. Jen nevím co se u toho novýmu přiučím. :-D Pokaždý prvně instaluju MB ale tentokrát je docela možný že jsem prvně udělal opak.
