DDR3
Dobrý den
Potřebuji přikoupit paměť a nevím kterou vybrat.
Můžete ni prosím poradit.
Mám: MT 16JTF25664AZ-1G4G1
2GB 2RX8 PC3-10600U-9-10-B0
OF CHINA
Děkuji Venda
Dobrý den
OF CHINA
Děkuji Venda
A jakou máš základní desku?
nevím jak to mám zjistit.
Třeba programem CPU-Z.
CPU-Z TXT Report
Binaries
CPU-Z version 1.70.0.x64
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.539 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Celeron E3400
Codename Wolfdale
Specification Intel(R) Celeron(R) CPU E3400 @ 2.60GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
TDP Limit 65 Watts
Core Speed 1199.9 MHz
Multiplier x Bus Speed 6.0 x 200.0 MHz
Rated Bus speed 800.0 MHz
Stock frequency 2600 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 13.0x
Max VID 1.288 V
To jsi ovšem nenapsal nic o desce. Co je napsané na záložce "Mainboard"?
Kup dalsi 2GB obojstranny 1333
nezlob se ale nic mi neříká to oboustranný.
Oboustrané RAM znamená, že má pamětové čipy na obou stranách modulu RAM.
Omlouvám se ale nevyznám se v tom.
Mainboard Model 2A8C (0x000000EE - 0x000025D8)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8721
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8721
LPCIO Revision ID 0x2
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 21 02 00 00 01 00 00 40 00 00 00 1F 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 10 0A 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A10
Tohle to na záložce Mainboard určitě nepíše.
Byl to Save Report TXT
Na záložce je:
Manufacturer - Faxconn
Model - 2A8C 1.1
Chipset - Intel G41 Rev. A3
Southbridge - Intel 82801GB (ICH7/R) Rev. A1
LPCIO - ITE IT 8721
Brand - American Megatrends Inc.
Version - 6.08
Date - 07/07/2011
Teď máš dva moduly, nebo jenom ten jeden 2GB?
jen ten jeden.
Mohla by fungovat tahle:
http://www.czc.cz/kingston-value-2gb-ddr3-1333_2/1 44374/produkt
nebude vadit že je každá jiná?
To se nedá vyloučit, i když to není moc pravděpodobné. V tom případě bys musel koupit dvě a tu původní vyhodit.
a v případě že budu kupovat 2 je lepší koupit 4GB nebo zůstat u 2GB?
http://pc.bazos.cz/inzerat/39953063/DIMM-DDR3-King ston-4GB-kit-2x2GB-1333MHz-BOX.php
2x2
děkuji
