BSOD
dobry den prosim vas o pomoc uz si nevim rady pokazde kdyz stahuju z torrentu tak mi to cca do 30 min spadne do bsod.
zkusil jsem prinstalovat drivery a pak i windows ale nepomohlo.
A prosim zadne odpovedi typu "nestahuj pres torrent a kup si to" atd.
kdyz zadam do prikazoveho radku "!analyze –v" tak mi to vypise toto:
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000005511, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88006125b91, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800033020e0
0000000000005511
CURRENT_IRQL: 2
FAULTING_IP:
athrxusb+76b91
fffff880`06125b91 8b402c mov eax,dword ptr [rax+2Ch]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: WinSAT.exe
TRAP_FRAME: fffff88003199790 -- (.trap 0xfffff88003199790)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=00000000000054e5 rbx=0000000000000000 rcx=0000000000000001
rdx=fffffa800e601030 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88006125b91 rsp=fffff88003199920 rbp=0000000000000000
r8=fffffa800e5cb2f8 r9=0000000000000000 r10=fffffffffff9f358
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
athrxusb+0x76b91:
fffff880`06125b91 8b402c mov eax,dword ptr [rax+2Ch] ds:00000000`00005511=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800030cb469 to fffff800030cbf00
STACK_TEXT:
fffff880`03199648 fffff800`030cb469 : 00000000`0000000a 00000000`00005511 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`03199650 fffff800`030ca0e0 : 00000000`00000000 fffffa80`0f0279b0 fffffa80`0f2c3bb0 00000000`00000001 : nt!KiBugCheckDispatch+0x69
fffff880`03199790 fffff880`06125b91 : fffff880`01468110 fffffa80`1077d950 00000000`00000286 fffff880`060c0380 : nt!KiPageFault+0x260
fffff880`03199920 fffff880`01468110 : fffffa80`1077d950 00000000`00000286 fffff880`060c0380 00000000`00000000 : athrxusb+0x76b91
fffff880`03199928 fffffa80`1077d950 : 00000000`00000286 fffff880`060c0380 00000000`00000000 fffffa80`1077d950 : ndis!WPP_GLOBAL_Control
fffff880`03199930 00000000`00000286 : fffff880`060c0380 00000000`00000000 fffffa80`1077d950 00000000`00000000 : 0xfffffa80`1077d950
fffff880`03199938 fffff880`060c0380 : 00000000`00000000 fffffa80`1077d950 00000000`00000000 fffff880`060eb331 : 0x286
fffff880`03199940 00000000`00000000 : fffffa80`1077d950 00000000`00000000 fffff880`060eb331 00000001`0f2b1020 : athrxusb+0x11380
STACK_COMMAND: kb
FOLLOWUP_IP:
athrxusb+76b91
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: athrxusb+76b91
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: athrxusb
IMAGE_NAME: athrxusb.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 46c54b08
FAILURE_BUCKET_ID: X64_0xD1_athrxusb+76b91
Followup: MachineOwner
Budu moc vdecny za kazdou radu.
upgraduj ovládač pre atheros usb wireless adapter,je to známy problémový hardware pod win vista a novším
Ale já když dam spravovat PC a tam dam aktualizovat ovladac tplink wireless adaptér tak mi to napíše ze je ovladač aktualni
Vista není čistá. Skus ťahať z nabútovaného Live Ubuntu, ako dopadne RAM.
Pri sťahovaní legálnych súboroch obdobnej veľkosti ti Vista nepadne?
Já mám W7
ako že máš win7,keď chybové hlásenie pochádza z win vista ? potom si čo inštaloval kam ? stiahni si ovládače pre používaný operačný systém a používaný wifi adaptér a nemiešaj ovládače pre iný operačný systém hlavne u známeho problematického hardwaru,vyhneš sa zbytočným problémom...
Pro toto zařízení jsem nenasel ovladač na w7.
Dole je odkaz na použity driver
je tam jasne chyba v ovládači pre atheros usb adaptér,to je známa a oficiálne priznaná chyba ovládačov pre tieto typy wireless čipov,tam v podstate nieje čo riešiť,len inštalovať ovládače,ktoré už dúfam boli aspoň čiastočne opravené,pokial sa v systéme wifi/3G/hsdpa usb adaptér v pc nenachádza,treba jeho ovládače zo systému odinštalovať,v tom prípade tam nemajú čo hladať v aktivovanom stave....
Od kud mám sehnat novější ovladač? Novější jsem nenašel.
http://cz.tp-link.com/support/download/?model=TL-W N422G&version=V1#tbl_a
pokial je to už starý nepodporovaný hardware,tak bohužial chybám nezabrániš,ovládače kompilované pre win2000 a spol nebudú fungovať,zakúp si novší adaptér s podporou a kompatibilitou s novými operačnými systémami,niekedy bohužial je nutné starý hardware nahradiť,pokial už výrobca starý hardware nepodporuje,s tým nič rozumného nevymyslíme
Pozri si aku mas HW verziu svojho adaptera FCC-ID:, budes tam mat V a cislo 1 alebo 2.
ale podla toho co som dohladal, tak aj verzia 1 aj verzia 2, ked pouzivaju cipset atheros, tak pouzivaju ten isty, link na driver https://www.atheros.cz/atheros-wireless-download.p hp?chipset=64&system=6
Ano presne tak ako hore ti pisu = mas stare PC a do neho si dal Windows 7 ktory vlastne tvoj stroj nepodporuje uplne (niesu ovladace).
Takze s chybami musis ratat ze ti to bude robit...
Kup si ked tak neaky RADIČ do PCI slotu alebo usb-wifi adapter ak vobec mas USB v pocitaci
A mimochodom ty si asi nainstaloval ovladace co su pre Windows Vista,,, do Windows 7 pravdepodobne tak preto ti to vychadzuje chybu.
