Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Problém s ovladači po přechodu z Win7 na win8
Nainstaloval jsem si Win8, všechno mi skvěle funguje, jenom hra (minecraft) mi pořád padá a píše mi to, abych nainstaloval aktuální ovladače ke grafickému hardwaru. Jenže vůbec nevím jak, kde vzít ty ovladače, ...
Píše mi to tohle :
---- Minecraft Crash Report ----
// Daisy, daisy...
Time: 31.12.14 21:18
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelForma t(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat (WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(Windo wsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java :306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bsu.am(SourceFile:523)
at bsu.aj(SourceFile:352)
at bsu.a(SourceFile:299)
at net.minecraft.client.main.Main.main(SourceFile:120 )
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8
Operating System: Windows 8.1 (amd64) version 6.3
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 129644448 bytes (123 MB) / 212336640 bytes (202 MB) up to 954728448 bytes (910 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerfor mance_javaw.exe_minecraft.exe.heapdump -Xmx1G
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8
LWJGL: 2.9.1
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
No oni si všichni samoadmini myslí, že reinstalace Windows je všechno, co musí udělat (oni víc ani n…
Kurt 31.12.2014 21:21
Kurt
Já mám grafickou kartu ATI Radeon HD 4600 series, nainstaloval jsem si na ní ovladače, ale někde mi…
Psychopath 31.12.2014 21:29
Psychopath
Tak jeste ty ostatni (aspon chipset).
Kurt 31.12.2014 21:32
Kurt
Promiň, asi si o mně budeš myslet, že jsem úplně blbý, ale jak poznám, jaký chipset si mám stáhnout…
Psychopath 31.12.2014 21:37
Psychopath
Podle typu zakladni desky.
Kurt 31.12.2014 21:42
Kurt
Je možné, aby chipset pro základní desku Gigabyte GA-MA790X-UD4 nebyl na Win8.1 ?
Psychopath 31.12.2014 21:58
Psychopath
Ano, je to možné. A jak jsem se díval, je tomu opravdu tak, výrobce této desky prostě vydal poslední… poslední
Zdenál 01.01.2015 15:07
Zdenál
Oooooochhh booože dalsi. Ludia si uz ZAPAMETAJTE ZE KED UPGRADE_UJETE Windows tak TREBA KOMPLET NAIN…
human0id 31.12.2014 21:36
human0id
Já mám nainstalované skoro všechny ovladače, ale asi mi tam nějaký chybí nainstalovaný a já nevím ja…
Psychopath 31.12.2014 21:41
Psychopath
u domácích instalatérů je neinstalace prvního ovladače úplně normální: http://pc.poradna.net/a/view/…
lední brtník 31.12.2014 23:45
No oni si všichni samoadmini myslí, že reinstalace Windows je všechno, co musí udělat (oni víc ani neumí). Ale není to tak úplně pravda - součástí instalace OS je i instalace ovladačů HW.
Takže zjistěte, co máte za grafickou kartu a nainstalujte ovladače. Při té příležitosti nainstalujte i ovladače chipsetu.
Já mám grafickou kartu ATI Radeon HD 4600 series, nainstaloval jsem si na ní ovladače, ale někde mi to pořád píše, že je nainstalovaný nemám, nebo že nejsou aktuální.. Ale já už fakt nevím, co mám stáhnout :/
Ludia si uz ZAPAMETAJTE ZE KED UPGRADE_UJETE Windows tak TREBA KOMPLET NAINSTALOVAT ZASE VSETKY OVLADACE A PRAVDEPODOBNE AJ VSETKY PROGRMAMI !!!
Upgrade sa odporuca (maju to napisane aj na stranke MRKVOSOFTU) hned na zaciatku ked si nainstalujes Windows a nemas tam nic okrem neho = ziadne programi ani hry.
