Ovladače k TV kartě
Moc vás všechny prosím o radu. Nevíte kde bych sehnal ovladače na win XP pro tuhle kartu? Už si opravdu nevím rady. Stahoval jsem je od výrobce, ale nefungovaly mi.
LEADTEK WINFAST TV2000 XP TV TUNER VIDEO CAPTURE CARD PAL DK,BG PCI INTERFACE
Velmi dobrá funkční TV, FM a Video karta, s řadou vstupů, včetně dálkového ovládače a českého manuálu.
Pro Windows 98SE/ME/2000/XP. Záruka 14 dní na vyzkoušení.
Specifikace:
P/N: W1200424
LR16606 PCB REV:1
Time-Shifting: you can pause, rewind live television and instant replay.
Take your break during a TV show or movie and never have to miss a scene
Versatile Remote Control : quick response user friendly remote control with power on/off the AP,
open TV, Full Screen, Time-shifting, REC, Playback, Picture-in-Picture, Snapshot, and so on. It also supports WinDVD.
Powerful schedule : you can schedule your TV recordings.
Support MPEG-1/MPEG-2/MPEG-4 and AVI video codes and MP3 audio codec configuration to get the smaller file size for capturing
8-bit Video Decoder and De-interlacing for Crystal Clear Display
Support PIP (picture in picture) function. One for live and the other for captured program. Best for time-shifting viewing
Preset TV channels with preferred name
Watch high-quality TV in full screen or a scalable window independent
Transfer video to PC from VCR, camcorder, LD/VCD/DVD player
Support video mail communication
Support Microsoft NetMeeting
Hardware Interface: 32-bit PCI 2.1 bus mastering
Compatibility: Graphics drivers must include DirectX 8.1 software Video Standards
Video Standards: NTSC, PAL or SECAM
TV Tuner:
NTSC, PAL I/DK, PAL BG/DK, PAL M/N, SECAM BG for respective model
Full 181 channels supported
Video Display: True color overlay in scaleable video-in-a-window
Video Format: RGB32/RGB24/RGB15/YUY2
Drivers: WDM drivers for Windows 98SE/ME/2000/XP
Ovladače pro Leadtek bych zkoušel hledat na stránkách Leadtek.
Na stránky výrobce tě nenapadlo jít?
http://www.leadtek.com/eng/product/6/169/intro.asp x#pitem=driver
Vždyť říkám, že mi ovladače od výrobce nefungovaly.
A co chceš aby na tom fungovalo?TV na tom nepojede,je to pouze analog(aspoň podle specifikace).
Chci , aby mi PC nehlásil neznámé zařízení. Chci tím převést video z kamery do digitální podoby.
Zkus se optat tady majitelů....http://www.czc.cz/leadtek-winfast-tv2000-xp-expert /24775/produkt/forum
A stahoval jsi správné ovladače? Tuhle kartu jsem měl taky a normálně s těmi ovladači fungovala.
A který ovladač to podle vás je?
ftp://ftp.eu.leadtek.com/tv_tuner/TV2000XPRM/08110 8/X86.zip
U toho mi PC píše: "This device does not suppored" Nevíte, čím by to mohlo být?
Jaký typ ti to hlásí ve správci úloh?
Jestli myslíte správce zařízení, tak tam je napsáno medialní zařízení a medialní video zařízení, jinak nic.
Ve vlastnostech určitě najdeš i bližší informace. Důležitý je DEV a VEN.
Dobře, dnes už jdu spát, ale zítra se podívám.
Našel jsem tohle:
Těch jsem se něco nainstaloval! Možná někde v pracovní zásuvce najdu i originál CD (byly na něm ovladače a aplikace pro sledování TV).
Nemate prosim vas to CD?
Nereagoval jste, tak jsem to neřešil. Zkusím se v pondělí podívat, vzpomenu-li si.
Byl bych vam za to moc vdecny. Nevidim uz jinou moznost.
Dle mého soudu to teď nerozchodíte ani s tím CD - máte nainstalovány nějaké jiné ovladače a instalátor z CD si s nimi neporadí (nedokáže je odebrat, aby je nahradil těmi správnými).
No ty snad odinstaluju. Mě jenom mate, že ten instalátor "TV2000 XP FM RM Deluxe(x86).exe" hlásí "This device does not suppored". Kdyby to šlo nainstalovat a nefungovalo tak dobře, ale ono to ani nejde nainstalovat.
Mám tu kartu i s CD,můžu Ti to CD v iso poslat.
edit-tady to máš-stáhni a vypal si CD:
megarapid.cz
http://www.fastshare.cz/4104631/winfast2000-cd.iso
Díky, zítra to vyzkouším.
Tohle ale neni k tv2000, je to k naky USB karte.
Nejen k USB.
Je to celé originální CD k té kartě.Zkusil jsi to alepoň spustit a nainstalovat ty drivery?
Zkusil. Nejde to. Pise to taky naky not supported a pres spravce zarizeni to nic nenajde.
To je přesně ta situace, o které jsem psal. Nejspíš mám stejné CD jako kolega, který je již poskytl, čili ani to moje vám nepomůže. Máte nainstalovány špatné ovladače a správné tam teď nedostanete - alespoň tedy ne bez reinstalace Windows.
Ne tím to není. Zkoušel jsem to na 2 dalších počítačích se 2 různými windowsy (winXP a win2000)
Tak mám jinou verzi - na mém CD je napsáno "Version: 5.4". ISO jsem nahrál sem:
http://www.fastshare.cz/4109168/mm5437-03292006.is o
Dufam ze mas nainstalovany Service pack 2 alebo 3 ?!
Mám. "Please have DirectX 9.0c or above installed before installing the driver and AP."
Co je to AP?
To bude obslužná aplikace.
Tyto screeny jsou z druhého PC. Nainstaloval jsem: ftp://ftp.nec-computers.com/REFFIUP04320100/TVtune r-XPdrv.exe a všechna neznámá zařízení zmizela. Ale pořád to nefunguje, viz obrázek. Už si opravdu nevím rady. Pomozte někdo, prosím!
To jsou špatné ovladače. Zkusil jsi ty ovladače od Leadteku nainstalovat ručně?
Pro typ deluxe nebo rm nebo fm je tam pouze soubor exe. Jak na to?
Ten exe rozbalit a najít složku, kde jsou .inf soubory.
Rozbalil jsem ho programem universal extractor a zkusil nainstalovat ovladace pres spravce zarizeni, ale opet bezuspesne.
prečo sťahuješ ovládače určené pre NEC-pc a tv karty od KWorld FlyTV ? hladaj ovládače na stránke Leadtek,nie na stránke japonského NEC,to sú dve úplne rozdielne veci
Mockrát vám děkuji za všechny vaše rady. Bohužel se mi kartu stále nepodařilo kartu uvést do chodu, pravděpodobně bude vadná. Koupil jsem tedy "novou".(z bazaru)
