Visual Basic
Select Case PictureBox36.Tag
Case "1" : PictureBox36.Image = mini1.Image
Case "2" : PictureBox36.Image = mini2.Image
Case "3" : PictureBox36.Image = mini3.Image
Case "4" : PictureBox36.Image = mini4.Image
Case "5" : PictureBox36.Image = mini5.Image
Case "6" : PictureBox36.Image = mini6.Image
Case "7" : PictureBox36.Image = mini7.Image
Case "8" : PictureBox36.Image = mini8.Image
Case "9" : PictureBox36.Image = mini9.Image
Case "10" : PictureBox36.Image = mini10.Image
Case "11" : PictureBox36.Image = mini11.Image
Case "12" : PictureBox36.Image = mini12.Image
Case "13" : PictureBox36.Image = mini13.Image
Case "14" : PictureBox36.Image = mini14.Image
Case "15" : PictureBox36.Image = mini15.Image
Case "16" : PictureBox36.Image = mini16.Image
Case "17" : PictureBox36.Image = mini17.Image
Case "18" : PictureBox36.Image = mini18.Image
Case "19" : PictureBox36.Image = mini19.Image
Case "20" : PictureBox36.Image = mini20.Image
Case "21" : PictureBox36.Image = mini21.Image
Case "22" : PictureBox36.Image = mini22.Image
Case "23" : PictureBox36.Image = mini23.Image
Case "24" : PictureBox36.Image = mini24.Image
Case "25" : PictureBox36.Image = mini25.Image
Case "26" : PictureBox36.Image = mini26.Image
Case "27" : PictureBox36.Image = mini27.Image
Case "28" : PictureBox36.Image = mini28.Image
Case "29" : PictureBox36.Image = mini29.Image
Case "30" : PictureBox36.Image = mini30.Image
Case "31" : PictureBox36.Image = mini31.Image
Case "32" : PictureBox36.Image = mini32.Image
Case "33" : PictureBox36.Image = mini33.Image
Case "34" : PictureBox36.Image = mini34.Image
Case "35" : PictureBox36.Image = mini35.Image
Case "36" : PictureBox36.Image = mini36.Image
Case "Else" : MsgBox("Neni" & PictureBox36.Tag)
End Select
K čemu přesně je tu využit tag?
CASE slouzi na overeni, jetli je tam to co hledas.
Já se ale ptám na vlastnost tag
• Nevim jak to napsat, ten .tag je aby si to zapamatoval, zapsal do pameti.
Tag obsahuje obecnou integer hodnotu. V tomto pripade se na zaklade hodnoty TAG zobrazi v PictureBox36 obrazek podle hodnoty TAG.
Ale prece neni zase tak slozite ten kod precist...
A jak se do tagu zapíše nějaká hodnota?
• Zrejme pres nakou knihovnu..
neco.Tag = nejaka_hodnota;
TAG je property objektu. Zrovna tak, jako kdyz priradis text treba do editu:
edit.Text = 'Muj prvni text v editu'
tak muzes zapsat Tag nebo priradit jakoukoliv jinou vlastnost - font, velikost, pozici, viditelnost...
Tag není integer, ale libovolný object, teda alespoň v .NETu.
V čemkoliv je to "libovolný objekt". Je to integer hodnota, do které můžeš zapsat ukazatel na objekt. Zřejmě to můžeš v :NET udělat přímo, v Delphi musíš použít
Neviem či si dal dobrý príklad:
Pointer(objekt) predsa nie je integer...
Ak by som chcel do vlastnosti objektu tag uložiť napr. nejaký text, potom asi nejak takto:
Omlouvám se, přetypovaní musí být na integer, ne na Pointer. Takže něco takového:
Jinak ten kód psal pracovitý pit*mec.
Šlo by to zapsat na řádek či dva.
Díky moc všem :) Vím jsem ale začátečník;)
Kde jsi ten kód vůbec sebral? Protože pokud se z něj chceš něco naučit, tak je přímo ukázkový - ukázka jak to rozhodně nedělat.
To je můj kod :D
To je tvůj kód a přitom nevíš, co dělá? To ho píšeš náhodnými údery do klávesnice?
Ne, prostě to někde zkopíruje a pastne a až má kódu 2 stránky, tak se mu to celé rozsype, protože neví, co to vlastně dělá
