Pc mi začal zamrzat po zataži
Dobrý den
Potreboval by som poradit prečo mi zamrza pc, Vždy ked po dlhšej dobe vypnem hru, tak do 20 sekund dostanem ciernu obrazovku, niekedy zelenu aj bielu a ventilator grafiky sa roztočí naplné otáčky. Hrat možem ako dlho chcem Mam windows 7, ktory som koli tomuto problemu preinstaloval, nemam nic pretaktovane, teplota grafiky v zatazi 74 a cpu 60. Robí to na viecerých hrách aj benchmarkoch ale ked znížim detaily grafiky na minimum a obmedzim si fps na 30 tak nespadne.
moja zostava:
GPU: GTX 780Ti GAMING 3G
CPU: Intel Core i7-4770K
MB: Z87-G45 GAMING
Ram: 8 GB Patriot G Series
SSD: Intel 530 bulk 120GB
HDD: WD500GB + WD 500GB + WD 250GB
PSU: ARCTIC Cooling Fusion 550 Watt
OS: Windows 7 Pro x64
Dnes mi windows vytvoril dmp subor
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\a\Desktop\051415-11840-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Mini Kernel Dump does not have process information
Symbol search path is: symbols
Executable search path is:
Unable to load image Unknown_Module_c01c15d8`0db64b06, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_c01c15d8`0db64b06
*** ERROR: Module load completed but symbols could not be loaded for Unknown_Module_c01c15d8`0db64b06
Debugger can not determine kernel base address
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18839.amd64fre.win7sp1_gdr.150427-0707
Machine Name:
Kernel base = 0xfffff800`03416000 PsLoadedModuleList = 0xfffff800`0365d730
Debug session time: Thu May 14 17:45:56.057 2015 (GMT+2)
System Uptime: 0 days 6:21:32.916
Loading Kernel Symbols
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa800ab5b270, fffff88009221a08, ffffffffc000009a, 4}
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
7: kd> !analyze -v
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa800ab5b270, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88009221a08, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
+643f952f053fda04
fffff880`09221a08 48ff258126edff jmp qword ptr [fffff880`090f4090]
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`0d27ca48 fffff880`07c83134 : 00000000`00000116 fffffa80`0ab5b270 fffff880`09221a08 ffffffff`c000009a : 0xfffff800`0348a8c0
fffff880`0d27ca50 00000000`00000116 : fffffa80`0ab5b270 fffff880`09221a08 ffffffff`c000009a 00000000`00000004 : 0xfffff880`07c83134
fffff880`0d27ca58 fffffa80`0ab5b270 : fffff880`09221a08 ffffffff`c000009a 00000000`00000004 00000000`00000001 : 0x116
fffff880`0d27ca60 fffff880`09221a08 : ffffffff`c000009a 00000000`00000004 00000000`00000001 fffffa80`0ab5b270 : 0xfffffa80`0ab5b270
fffff880`0d27ca68 ffffffff`c000009a : 00000000`00000004 00000000`00000001 fffffa80`0ab5b270 fffff880`07c56867 : 0xfffff880`09221a08
fffff880`0d27ca70 00000000`00000004 : 00000000`00000001 fffffa80`0ab5b270 fffff880`07c56867 fffff880`09221a08 : 0xffffffff`c000009a
fffff880`0d27ca78 00000000`00000001 : fffffa80`0ab5b270 fffff880`07c56867 fffff880`09221a08 fffffa80`0838b000 : 0x4
fffff880`0d27ca80 fffffa80`0ab5b270 : fffff880`07c56867 fffff880`09221a08 fffffa80`0838b000 00000000`00000000 : 0x1
fffff880`0d27ca88 fffff880`07c56867 : fffff880`09221a08 fffffa80`0838b000 00000000`00000000 ffffffff`c000009a : 0xfffffa80`0ab5b270
fffff880`0d27ca90 fffff880`09221a08 : fffffa80`0838b000 00000000`00000000 ffffffff`c000009a fffffa80`0774c410 : 0xfffff880`07c56867
fffff880`0d27ca98 fffffa80`0838b000 : 00000000`00000000 ffffffff`c000009a fffffa80`0774c410 fffffa80`09042d50 : 0xfffff880`09221a08
fffff880`0d27caa0 00000000`00000000 : ffffffff`c000009a fffffa80`0774c410 fffffa80`09042d50 fffffa80`0774c410 : 0xfffffa80`0838b000
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: CORRUPT_MODULELIST
7: kd> lmvm Unknown_Module
start end module name
Dakujem za rady
pro jistotu bych nechal běžet memtest (patriot je low-end).
nějaké čističe používáš?
jedna technická: máš ssd a 3 hdd? ten 250gb nic nepřináší, vyhoď ho. budeš mít lepší proudění vzduchu.
memtest som mal pusteny asi hodinu ale dam ho este nanoc a ano mam jeden ssd a 3 hdd ale vsetky prisrobovane miesto dvdmechaník
teď se dívám - "VIDEO_TDR_FAILURE (116)"
https://msdn.microsoft.com/en-us/library/windows/h ardware/ff557263%28v=vs.85%29.aspx
zkus jinou verzi ovladače grafiky.
pokud se to ani s jinými drivery nezlepší, reklamuj hardware (grafiku).
skladal som novy pc z ktoreho som vyskusal 600w zdroj, ssd bez ostatnych diskou aj ramky stale to pada a grafiku som skusil v tom novom pc a nespadlo to ale ten pc mal slabsi cpu a mozno grafiku dostatocne nezatažil, tak neviem, en dufam ze to bude nejaky software
preinstalovatsom si windows druhy krat a dal som ovladace len z cd pada to stale, skusal som grafiku v inom slabsom pc ale aj 960 GTX v mojom pc a nespadlo. Mozno sa mi ta grafika nevytazila naplno so slabsim cpu. Skusal som aj podtaktovat na 600 mhz jadro gafiky teploty som mal 60 stupnou ale vyuzitie grafiky 99% - 100% a spadlo aj tak. Teraz to moze robit bud grafika alebo doska a neviem co reklamovat
já jsem nic nepsal o vytěžování grafiky, ale o jiné verzi ovladače.
instaluješ vůbec základní ovladač?
to měříš v čem?
jo zkousel jsem preinstalovat a instalovat ovladace z cd, merim to v afterburneru. Na afterburneru jsem dal max teplotu 60 a grafika semi podtaktovala na 600 mhz ale pořád jela na 99% a padlo stejne. Mel jsem ovladace pro gta V ted mam 331.82. Pc mi nespadne kdyz dam low detaily a lock fps na 30, tehdy se mi grafika nevitezi naplno. Mozna je to prave tim vytizenim nevim
