Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem minecraft padání hry
prosím o pomoc... pořád mi padá minecraft přikládám game output
Starting up SoundSystem...
Initializing LWJGL OpenAL
(The LWJGL binding of OpenAL. For more information, see www.lwjgl.org)
OpenAL initialized.
[12:55:51] Loaded module: [0] Xray.
[12:55:53] Loading Huzuni.
[12:55:53] Current EventAPI version: 0.6-beta
[12:55:53] Huzuni version : 3.2.1
[12:55:53] Loading modules...
[12:55:53] Loaded module: [1] Anti AFK.
[12:55:53] Loaded module: [2] Auto TPA Accept.
[12:55:53] Loaded module: [3] CASPER.
[12:55:53] Loaded module: [4] Friendsafe.
[12:55:53] Loaded module: [5] GUI.
[12:55:53] Loaded module: [6] Middle Click Friends.
[12:55:53] Loaded module: [7] Respawn.
[12:55:53] Loaded module: [8] Auto Harvest.
[12:55:53] Loaded module: [9] Kill Aura.
[12:55:53] Loaded module: [10] Anti Knockback.
[12:55:53] Loaded module: [11] Auto Disconnect.
[12:55:53] Loaded module: [12] AutoSoup.
[12:55:53] Loaded module: [13] Criticals.
[12:55:53] Loaded module: [14] Projectiles.
[12:55:53] Loaded module: [15] Regen.
[12:55:53] Loaded module: [16] Trigger Bot.
[12:55:53] Loaded module: [17] Nuker.
[12:55:53] Loaded module: [18] AutoFish.
[12:55:53] Loaded module: [19] Vehicle 1-Hit.
[12:55:53] Loaded module: [20] Dolphin.
[12:55:53] Loaded module: [21] Flight.
[12:55:53] Loaded module: [22] Glide.
[12:55:53] Loaded module: [23] NoFall.
[12:55:53] Loaded module: [24] Spider.
[12:55:53] Loaded module: [25] Sprint.
[12:55:53] Loaded module: [26] Breadcrumbs.
[12:55:53] Loaded module: [27] Bright.
[12:55:53] Loaded module: [28] Chest ESP.
[12:55:53] Loaded module: [29] NameTags.
[12:55:53] Loaded module: [30] Status HUD.
[12:55:53] Loaded module: [31] Tracer.
[12:55:53] Loaded module: [32] WireFrame.
[12:55:53] Loaded module: [33] Auto Tool.
[12:55:53] Loaded module: [34] Fastplace.
[12:55:53] Loaded module: [35] Freecam.
[12:55:53] Loaded module: [36] Night Vision.
[12:55:53] Loaded module: [37] Retard.
[12:55:53] Loaded module: [38] Sneak.
[12:55:53] Loaded module: [39] Speedmine.
[12:55:53] Loaded module: [40] Step.
[12:55:53] Loaded module: [41] Auto Build.
[12:55:53] Loaded module: [42] Chest Stealer.
[12:55:53] Loaded module: [43] Anti Censor.
[12:55:53] Loaded module: [44] Dolan Speak.
[12:55:53] Loaded module: [45] Auto Armor.
[12:55:53] Loaded module: [46] Tips.
[12:55:53] Loaded module: [47] Fast Ladder.
[12:55:53] Loaded 48 modules.
[12:55:53] Loading commands...
[12:55:53] Loaded 32 commands.
[12:55:53] Loading themes...
[12:55:53] Loaded 14 themes.
[12:55:53] Set huzuni to: true.
[12:55:53] Set antialiasing to: true.
[12:55:53] Set globalfont to: false.
[12:55:55] Finished loading Huzuni.
[12:55:57] Initialized new hk.
[12:56:4] Initialized new tk.
[12:56:5] Initialized new uk.
[12:56:20] Initialized new uk.
[12:56:25] Initialized new uk.
[12:57:19] Toggled module: Flight to state: true.
[12:57:20] Toggled module: Flight to state: false.
[12:57:24] Toggled module: Flight to state: true.
[12:57:26] Toggled module: Flight to state: false.
[12:58:27] Toggled module: Flight to state: true.
[12:58:28] Toggled module: Flight to state: false.
[13:0:10] Toggled module: Flight to state: true.
[13:0:11] Toggled module: Flight to state: false.
[13:0:27] Initialized new uk.
[13:0:28] Initialized new uk.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000000cdeb935, pid=6712, tid=4100
# JRE version: Java(TM) SE Runtime Environment (7.0_72-b14) (build 1.7.0_72-b14)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.72-b04 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig7icd64.dll+0x6b935]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Jakub\AppData\Roaming\.minecraft\hs_err_p id6712.log
# If you would like to submit a bug report, please visit:
# crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
herní poradnu máme vedle: hry.poradna.net poslední
icepower32 12.07.2015 13:09
icepower32
