Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Jak nastavit Router AirLive Air4G, aby počítačům připojeným za routerem fungovala aplikace GameRange
Dobrý den.
Dcerka se mnou chce hrát hry po internetu a kromě programu Hamachi, který mi nepomohl, jsem včera úspěšně odzkoušel program GameRanger.
Postupoval jsem v nastavení GameRangeru podle návodu a podařilo se mi na několik her propoji můj stolní PC s dceřiným Notebookem přez WiFi. Dnes jsem to zkusil znovu, ale nejde to.
Program GameRanger při mém pokusu založit hru vyhodí hlášku:
"Port-Restricted Cone NAT Router"
(Your internet connection is behind a Port-Restricted Cone NAT Router that may prevent a small percentage of players from joining your games.)
Learn More:
You will still be able to connect with the majority of players, but not with those who have Symmetric NAT Routers (which are not that common, fortunately). One advantage of fixing this problem is that the "Preparing Connection" window will complete much faster.
If you do want to solve this problem, it will involve you configuring your router. Most routers are configured through a web page built into them. You may be able to reach yours here.
Many recent routers support a feature called Universal Plug and Play (UPnP). This feature will allow GameRanger to do most of the configuration required. You will need to enable it to allow GameRanger to make changes. Not all routers support UPnP correctly, however, so that may not be enough.
The alternative is to manually configure your router to do port-forwarding for UDP port 16000. Ask your ISP (Internet Service Provider) or refer to your router's instruction manual for assistance here.
Port-forwarding tells the router to send the game communication data to your computer. The port-forwarding configuration page will ask you for a public port and a private port. Set both of those to 16000. In some cases, instead of asking for a public port, it will ask for a port range (eg. Start Port, End Port). Set the Start and End to 16000. It will also ask you for the IP address of your computer that the data should be sent to. It may call this the LAN IP, Local IP, or Private IP. This should be set to 192.168.1.100. If it asks you for the protocol or type, set it to UDP.
Unfortunately, it is not possible to offer step-by-step instructions here as every router is different.
If you are at work on a company network or at a university, you may not be able to fix the problem yourself. Instead you may have to ask the network administrator to how to port-forward UDP port 16000 to your computer.
Potíž je, že neumím Anglicky. Pochopil jsem, že se musí provést nějaká změna v nastavení Routeru, jenže i nastavení Routeru je v Angličtině a tak vůbec netuším co se po mě chce a co a jak nastavit.
Mám router AirLive Air4G.
Link na uživatelský manuál:
http://fs.airlive.com/manual/AirLive_Air4G_Manual. pdf
Pomůže mi někdo zkušený?
Heslovite. 1. Na hranie hier nepotrebujes mat Hamachi ani nic ine. 2. AK potrebujes mat z nejakeho d…
fleg 04.08.2015 12:01
fleg
Od Providera mám přidělenenou Veřejnou IP a rád bych provedl nastavení v Routeru, ale neumím anglick…
SlimmJim 04.08.2015 12:12
SlimmJim
Ja to vidim tak, ze si budes musiet pockat na niekoho trpezliveho s kopcom volneho casu (ten ja bohu…
fleg 04.08.2015 16:37
fleg
V počítači se vyznám velmi dobře, dělám i správce přátelům, je to moje hobby, ale neumím anglicky a…
SlimmJim 04.08.2015 18:35
SlimmJim
10 eur za jednorazovy zasah, co je tusim nejakych 270 CZk ak sa nemylim.
fleg 04.08.2015 21:25
fleg
Tak změna... Router jsem úplně odpojil a PC připojil přímo na modem. Odinstaloval včetně veškerých…
SlimmJim 06.08.2015 15:52
SlimmJim
Windows firewall, pripadne firewall nejakeho all in one sw.
fleg 06.08.2015 20:29
fleg
Já ale vypnul všechny firewall's co mám. Windows FW nepoužívám vůbec. Používám FW v Norton360 a přid…
SlimmJim 06.08.2015 23:26
SlimmJim
A tu verejnu ip adresu mas na tom PC? Pozri si ipconfig /all a musis mat verejnu ip adresu ak uz mas…
fleg 07.08.2015 18:04
fleg
Mám veřejnou IP. To byla moje podmínka k poskytovateli při zřizování internetu, protože jsem věděl,…
SlimmJim 08.08.2015 09:36
SlimmJim
Ja som sa pytal, ci mas verejnu ip adresu na pc, pretoze ak je v ceste len modem (mas kablovku predp…
fleg 08.08.2015 09:59
fleg
V routri na WAN strane mas teda aktualnu IP 89.203.neco.neco? Skontroluj si to tam kdesi na status s…
MM.. 08.08.2015 13:48
Ked je pripojene PC priamo na modem, tak mas v tom PC jaku IP? Vypises si ju prikazom ipconfig /all…
MM.. 08.08.2015 13:49
Podla IP adresy ide cez kabelovku a kabelovky zvyknu pouzivat modemy s jednym ethernet portom, takze…
fleg 09.08.2015 07:36
fleg
Je to přesně tak. Jsem na internetu prostřednictvím kabelovky. * Když mám PC připojený napřímo přez…
SlimmJim 10.08.2015 22:40
SlimmJim
Tak mládeži... Po mnoha různých pokusech a experimentech se mi podařilo nějakým zázrakem spustit na… poslední
slimmjim 11.08.2015 22:32
slimmjim
Heslovite.
2. AK potrebujes mat z nejakeho dovodu otvorene porty musis mat verejnu ip adresu. O tom, ci mas, ci nie rozhoduje tvoj ISP.
3. AK ti ISP prideluje verejnu ip adresu am ju tvoj router/modem a na nom musis nastavit portforwarding na pc, ktore to vyzaduje. Port forwarding sa robi podla manualu dodaneho k tvojmu routru.
Od Providera mám přidělenenou Veřejnou IP a rád bych provedl nastavení v Routeru, ale neumím anglicky a ten uživatelský manuál je také v angličtině. Proto jsem do topiku uvedl i link na manuál, aby se tam mohl podívat ten, kdo mi bude most poradit.
Ja to vidim tak, ze si budes musiet pockat na niekoho trpezliveho s kopcom volneho casu (ten ja bohuzial nemam), pretoze pri tvojej znalosti PC a hlavne anglictiny to bude este na tak 10 otazok a odpovedi kym by sme nasli nejaky vysledok alebo mozes skusit vyuzit nase komercne sluzby na it.poradna.net, kde je sice tiez nutna tvoja interakcia, ale cez telefon, ci skype + TV(teamviewer) by to uz ist malo relativne bez problemov.
V počítači se vyznám velmi dobře, dělám i správce přátelům, je to moje hobby, ale neumím anglicky a tak ve složitějších nastaveních aplikací které neznám samozřejmě tápu. TeamViewer používám často; (skvělá vychytávka). Právě jsem pomocí něj opravil nastavení otcova PC. Co se týče té placené služby... Na kolik by to vyšlo?
Tak změna...
Router jsem úplně odpojil a PC připojil přímo na modem. Odinstaloval včetně veškerých nastavení GameRanger a opět ho nainstaloval. Vypnul jsem Firewall a pokusil se hostovat hru v 'GR' a výsledkem je hláška:
VŮBEC NECHÁPU JAK JE MOŽNÉ, ŽE SE NĚCO TAKOVÉHO STALO, KDYŽ POČÍTAČ NENÍ NA ROUTER VŮBEC PŘIPOJENÝ.
Je to přesně tak.
* Když mám PC připojený napřímo přez modem, mám veřejnou IP.
* Když mám PC připojený na router, mám virtuální IP.
Potíž je, že to nefunguje, ať jsem připopjený jakkoliv.
Tak mládeži...
Po mnoha různých pokusech a experimentech se mi podařilo nějakým zázrakem spustit na GameRangeru místnost s hostovanou hrou Need foe Speed: Underground 2 a dokonce se na mě mohou i přez nepřetržitou hlášku o tom, že je něco s NAT v routru v nepořádku, přihlísili i další hráči.
Čímž jsem to tak trochu rozchodil.
Ale každopádně přejdu na nový router TP-LINK TL-WR1043ND, který má jednoduché ovládání a nastavení NAT.
* 802.11b/g/n až 450Mbps
* 1x GigabitWAN
* 4x GigabitLAN
Jde o to že nám v sídlišti dělají Optické připojení a tak se to bude výborně hodit.
Mimochodem... Dočetl jsem se že aby NFSU2 chodilo správně na Win7 x64, je potřeba mít doinstalovaný protokol IPX/SPX, který je ale v 7 nedostupný.
Jedinou možností je nainstalovat Vitrul PC + Vitrual XP Mod + doinstalovat kýžený protokol a následně celé síťové připojení povolit v 'Integrační Funkci'.
Tak tomu říkám pakárna :(
Avšak provedeno a funguje to.
