You need a driver for the controller to which your DVD-drive or installation media is connected. Do…
MM.. 11.08.2015 20:30
I rly dont know what a fck u talking about
Slipy 11.08.2015 20:44
Slipy
Když nechápeš anglicky psaný text, zkus to česky.
karel 11.08.2015 20:51
What ?
Slipy 11.08.2015 21:23
Slipy
If you dont understand what I wrote, do not try to install windows. I am locking it.
MM.. 11.08.2015 21:30
BTW. if you are using internal DVD drive, try to set SATA mode to IDE in BIOS Setup. poslední
MM.. 11.08.2015 22:00
Do not use USB3.0 ports, use USB2.0 port. Win7 does not know USB3.0 controllers. Or use internal DVD drive (usually connected to a standard SATA controller)
Zpět do poradny Nahoru
