Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Sekundové výpadky
Zdravím mám problém s internetem a to takový že mi to vypadne na sekundu dvě a potom to zase naskočí a pořád se to opakuje dokola ..
Nov 19 18:00:24 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:00:26 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:01:01 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:01:03 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:01:11 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:01:13 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:01:16 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:01:18 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:01:22 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:01:24 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:01:29 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:01:32 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:01:41 rc_service: udhcpc_lan 1641:notify_rc start_dnsmasq
Nov 19 18:01:41 ntp: start NTP update
Nov 19 18:02:23 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:02:26 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:02:26 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:02:28 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:04:02 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:04:04 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:04:17 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:04:19 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:04:56 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:04:58 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:05:33 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:05:35 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:06:13 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:06:15 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:06:41 rc_service: udhcpc_lan 1655:notify_rc start_dnsmasq
Nov 19 18:06:41 ntp: start NTP update
Nov 19 18:06:54 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:06:56 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:07:27 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:07:29 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Nov 19 18:07:31 kernel: ESW: Link Status Changed - LAN1 (P3) Link DOWN
Nov 19 18:07:33 kernel: ESW: Link Status Changed - LAN1 (P3) Link UP
Asi mas vadny LAN kabel
MM.. 19.11.2015 18:14
když se připojím na tvrdo bez routru tak to nedělá. A navíc jsem koupil nové a dělá to i na wifi
mara1121 19.11.2015 18:16
mara1121
Na wifi ti urcite nevypisuje link down. Ked to robi router tak mas vadny router.
MM.. 19.11.2015 18:26
Jsem připojený na wifi. A router jsem kupoval 2 týdny zpátky.
mara1121 19.11.2015 18:29
mara1121
Si pripojeny na wifi, a mas sucasne aj strceny nejaky kabel v LAN konektore? Ak ano tak su tie hlask…
MM.. 19.11.2015 18:43
Je v AP modu za druhým routrem
mara1121 19.11.2015 19:14
mara1121
A ten kabel medzi AP a routrom si uz skusal menit? Alebo iny vystup routeru? Robi to teda aj s LAN k…
MM.. 19.11.2015 19:16
lan1 který blbne není připojení počítače ale přivod internetu z předřazeného routru
mara1121 19.11.2015 19:26
mara1121
Este ti moze v tom PC blbnut LAN controller, skus uplne deaktivovat LAN controller a pouzivat potom…
MM.. 19.11.2015 19:17
router je z aukra? doma jsou nějaké mobily a tablety? zabezpečení wifi v routeru je nastaveno napevn…
lední brtník 19.11.2015 18:35
Routr je z euronics. Mobil je připojený 1. wifi je bez hesla jestli myslíte toto. euronics je hnůj…
lední brtník 19.11.2015 19:05
Asus RT-N12E
mara1121 19.11.2015 19:18
mara1121
nevím, proč ten krám vypadává. http://pc.poradna.net/f/view/1442961-chyba-zabezpe ceni-routeru-asus
lední brtník 19.11.2015 20:25
Takže co s tím mám dělat ??
mara1121 19.11.2015 21:32
mara1121
když se připojím na tvrdo bez routru tak to nedělá updatnout firmware. případně alternativní dd-wrt…
lední brtník 19.11.2015 21:51
Máš-li možnost, tak proměř, nebo vyměň, napájecí zdroj toho routeru, možná je to zmetek a nestabilní… poslední
Kachlík 20.11.2015 11:58
Kachlík
euronics je hnůj a ne obchod s pc zbožím. čekal jsem, že tě napadne napsat typ routeru: euronics klidně může znamenat "značku" evolveo a to je teda trus.
kvůli nevychovaným ovladačům mobilů a tabletů se zabezpečení nastavuje napevno na wpa2 + aes.
vypnuté zabezpečení je taky jednoznačná volba, ale odporuje to 802.11n, třeba je z toho router na prášky.
