visty zlobí
Ahoj, mam problem a nevim co s nim.
Vecne se mi objevuje takova chybova hlaska:
"Program COM Surrogate přestal pracovat."
Ta hlaska je fakt otravna, objevuje se mi kdyz chci neco zkopirovat, otevrit slozku, pustit video...
Nevite nekdo co s tim? Diky moc
Do you know Google?
227
jo, znam, akorat mi to nic nenaslo, pac jsem se jak ted vidim preklepl. omlouvam se a diky
Predpokladam ze mas nainstalovane Nero, ak ano staci odstranit jeho filtre a chybova hlaska je prec. C:/Program Files/Common Files/Ahead/DSFilter. Ak ti to nepojde odstranit vystrihni si ho na plochu.(potom odstran)
Mohu potvrdit, že to pomohlo. SUPER.
The fix involves adding the dllhost.exe to the Data Execution Protection (DEP) Ignore list. Here's the method in Vista (all Flavors):
Right click My Computer, select Properties - select Advanced System Settings from the left side pane - in the Performance box, click Settings - click Data Execution Prevention tab - Check the "Turn on DEP for all programs and services except those I select" option - click "Add".
A navigation box opens, navigate to C:\WINDOWS\system32\dllhost.exe, click it to add and hit OK.
This should now add this "Com Surrogate", with a checked box, into the list area, OK out, reboot and you're done. The Com Surrogate errors should disappear.
Zkus Tohle mne to pomohlo
Čtvrt roku.
