Problém s aplikací cordova
Ahoj, poradil by mi prosím někdo s tímto problémem ? Vůbec nevím co se mu nelíbí. Zkoušel jsem něco googlit ale je to bída :(
C:\cordova>cd hello
C:\cordova\hello>cordova build
Running command: cmd "/s /c "C:\cordova\hello\platforms\android\cordova\build. bat""
[Error: Please install Android target: "android-22".Hint: Open the SDK manager by running: C:\Users\hjan\AppData\Local\Android\android-sdk\to ols\android.BAT
You will require:
1. "SDK Platform" for android-22
2. "Android SDK Platform-tools (latest)
3. "Android SDK Build-tools" (latest)]
ERROR building one of the platforms: Error: cmd: Command failed with exit code 2
You may not have the required environment or OS to build this project
