File>Document properties>General>Default units [https://wiki.nottinghack.org.uk/images/thumb/2/20/…
host 26.03.2016 00:28
Děkuji, funguje to. poslední
Belcanto 31.03.2016 13:40
Belcanto
Nepoužívám, podle návodu to nefunguje? Changing the rulers' unit of measure In the default template…
karel 26.03.2016 00:31
In the default template, the unit of measure used by the rulers is px (“SVG user unit”, in Inkscape it's equal to 0.8pt or 1/90 of the inch). This is also the unit used in displaying coordinates at the lower-left corner and preselected in all units menus. (You can always hover your mouse over a ruler to see the tooltip with the units it uses.) To change this, open Document Properties (Shift+Ctrl+D) and change the Default units on the Page tab.
