Asus RT-N18U problém s odpojením
Zdravím,
poradil by mi někdo s tímto?
Router Asus RT-N18U spojený (mimo jiné) s TV Samsung LE37D550 - kabelem, na které běží pohádky ze Zyxel NSA310 přes DLNA, problém je, že se TV čas od času od NSA odpojí, přijde mi to jako zcela náhodné (někdy OK, teď 2x během hodiny), ale kouknul jsem na log z routeru a jsou tam mraky těchto záznamů (adresa 192.168.1.52 je TV)
Díky
Apr 26 13:33:56 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 15:58:09 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 15:58:22 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 18:11:23 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 18:49:15 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 18:49:28 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 19:11:21 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 19:11:34 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 19:38:39 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 20:37:47 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
Apr 26 20:38:09 dnsmasq-dhcp[382]: not giving name localhost to the DHCP lease of 192.168.1.52 because the name exists in /etc/hosts with address 127.0.0.1
máš v síti něco pojmenované localhost? vůbec nevím, co tím chce router říct. tak oběma krámům nastav statické adresy, dhcp je jen pro mobilní krámy.
Já taky vůbec nevím, co tím chce říct...
NSA, TV1, TV2 mají statické adresy 198.168.1.50-52 (připojeno kabelem), přidělování adres přes DHCP mám pro mobilní krámy a notebooky od rozsahu 192.168.1.100
Zkusím pohledat, jestli všude sedí MAC adresy, Localhost podle mně nic nemám, ale zkusím zkontrolovat (sítě znám jenom z rychlíku,
dík.
