Nefunguje psaní háčku a čárek nad jinýma písmenama, než na ty, které jsou v nabídce na klávesnici
Prosím o radu, kohokoliv... Nejde mi psaní háčků a čárek na klávesnici..
výpis s hijack:
Running processes:
C:\Program Files\VIA XHCI UASP Utility\usb3Monitor.exe
C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
C:\Windows\SysWOW64\rundll32.exe
C:\Program Files (x86)\Skype\Phone\Skype.exe
C:\Program Files (x86)\Bloody6\Bloody6\Bloody6.exe
C:\Program Files\AVAST Software\Avast\AvastUI.exe
C:\Users\Lukáš PC\Downloads\hijackthis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = fwlink
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = p
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = p
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = fwlink
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = fwlink
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = p
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe
O2 - BHO: Lync Click to Call BHO - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre1.8.0_72\bin\ssv.dll
O2 - BHO: avast! Online Security - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} - C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre1.8.0_72\bin\jp2ssv.dll
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\amd64\CLIStart.ex e" MSRun
O4 - HKLM\..\Run: [AvastUI.exe] "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
O4 - HKLM\..\Run: [MalwareProtectionLive] C:\Users\Lukáš PC\AppData\Local\MalwareProtectionLive\MalwareProt ectionClient.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [LogMeIn Hamachi Ui] "D:\Hamachi\hamachi-2-ui.exe" --auto-start
O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files\DAEMON Tools Lite\DTLite.exe" -autorun
O4 - HKCU\..\Run: [Steam] "D:\STEAM\steam.exe" -silent
O4 - HKCU\..\Run: [CCleaner Monitoring] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
O4 - HKCU\..\Run: [46583e39c4b3e12c3a7601c312ffe0b8] "C:\Users\Lukáš PC\AppData\Roaming\Adobe Flashplayer Service.exe" ..
O4 - HKCU\..\Run: [Skype] "C:\Program Files (x86)\Skype\Phone\Skype.exe" /minimized /regrun
O4 - HKCU\..\Run: [Bloody2] "C:\Program Files (x86)\Bloody6\Bloody6\Bloody6.exe" Minimum
Další čistič. Máš zapnutou českou klávesnici a píše to teda co? Začalo to samovolně?
Ano mám.. Nejdřív to nepsalo jenom na Facebooku a pak to jaksi přešlo všude.
Všude znamená v prohlížeči nebo i třeba v notepadu? V jiných prohlížečích než v tom oném to dělá taky?
Všude...
A co to teda dělá?
Napíše to akorát to písmeno, ale bez háčku / čárky
Chápem dobre, že nevieš napísať napr veľké "Č" ale keď píšeš malé "č", tak je to OK, lebo to je na klávesnici?
Alebo nevieš napísať háček na písmeno, na ktoré sa háček v češtine nepíše?
malé č napíšu a dokonce vím, jak se dělá i na jiných, ale nefunguje mi to.. Č velké č udělám s CAPSLOCKEM
Alt + 0200 funguje? Zkusils už aspoň ten MBAM?
Ano, alt + 0200 funguje... a ten MBAM sem taky dělal.. našlo mi to 2 soubory, tak sem to smazal + restartoval PC... problém přetrvává
- avast ničemu nezabrání
- ccleaner nic neumí opravit, spíš zruší co nemá
- C:\Windows\SysWOW64\rundll32.exe ... to není celý příkazový řádek, za tím bývá program nebo vir. bývá to vidět v msconfig.exe -> po spuštění
- O4 - HKCU\..\Run: [46583e39c4b3e12c3a7601c312ffe0b8] "C:\Users\Lukáš PC\AppData\Roaming\Adobe Flashplayer Service.exe" ... toto bude podvod = asi spyware. killni v paměti a smaž z disku.
tipnem si ze toto je tiez vir
autori maju dobry zmysel pre humor :) (ten nazov)
Na to by měl MBAM stačit, ale asi si to tam nainstaloval sám a dobrovolně.
malware-protection-live
Tak problém to vyřešilo na ostatních prohlížečích, ovšem na chromu pořád přetrvává. Nějaké jiné nápady?
Zbavit se Chrome včetně všeho v jeho profilu a začít znova, například. Možná by stačil nový profil.
Ano mame napad, odvir si chrome. Idealne takym tlacitkom ze uninstall. A potom to uz nikdy neinstaluj.
Problém vyřešen :D bylo to Adobe FlashPlayer service
bylo to tím Adobe Flashplayer service
Bylo to tím Adobe FlashPlayer service :) děkuji ti
ne přesně.
jedna věc je malware v paměti, jiné z těch škodných fungují jako downloader virů, jejich sestavovač a hlídač automatického spuštění.
pokud jsi zarytým uživatelem nejzaspywarovanějšího prohlížeče (chrome), můžeš se tak co měsíc-dva bavit kontrolou na spyware a adware.
odvir si to, MBAM, adwcleaner, eset online scanner, v nudzovom rezime windows. A odinstaluj ten zbytocny avast a cleaner rozdrbavac.
