Prehravanie hudby na TS3
zdravim,...vedeli by ste mi poradit ako prehravať hudbu na TS,ale ak by sa dalo aby som tomu mohol nastavit aj hlasitost pre ostatnych a nebolo to kvalitou zle? ....
skusal som toto :
1.1 -> Go in your Record Settings on your your System (where you set the Mic).
1.2 -> Make a right-klick in this Field
1.3 -> "Show deactivatet Devices"
1.4 -> Now you should see the Stereo Mix.
1.5 -> Aktivate it.
1.6 -> Use Stereo Mix as Record Device (TS, Skype, etc.).
1.7 -> Now all Sounds that you are hear listen Users in your Channel.
Ale kvalita nieje nič moc...
