Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Nejde mi Pokémon go
ahoj mám problém s Pokémon go: Zapnu hru, přihlásim se a napíše to chybu: "this device OS or software Is not compatible with Pokémon go" nevíte jak to opravit ? Mám mobil Acer z520, tovární nastavení jsem zkoušel a safety net test skončí neúspěšně
Díky za pomoc
Pokémon GO Application Compatibility Information Android: Compatible with Android devices that hav…
pme 24.02.2017 20:22
pme
Mám verzi s 2GB RAM a 16 GB ROM a dřív mi to šlo
Denis Baťa 24.02.2017 20:35
Denis Baťa
Tak ja neviem... Compatibility information may be changed at any time on either iOS or Android platf… poslední
pme 24.02.2017 20:47
pme
Android:
Compatible with Android devices that have 2 GB RAM or more and have Android Ver. 4.4–6.0 installed.
Not compatible with Android devices that use Intel Atom processors.
Compatibility with tablet devices is not guaranteed.
Application may not run on certain devices even if they have compatible OS versions installed.
Notes:
It is recommended to play while connected to a 3G/4G network in order to obtain accurate location information.
Compatibility is not guaranteed for devices without GPS capabilities or devices that are connected only to Wi-Fi networks.
Compatibility information may be changed at any time on either iOS or Android platforms.
Information current as of July 13, 2016
!!! Tvoj mobil nespĺňa minimálne veľkosť RAM... !!!
Tak ja neviem...
[l-4199.jpg]
