Bluescreen problem
Dobrý deň mam problem vždy pri zapnuti PC dava pasiky po obrazovke a potom hodi bluescreen skušal som preinštalovat OS ale nepomohlo vždy po nainstalovani ovladačov na grafiku to robi zase
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1051
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA800562B010
BCP2: FFFFF88004101CAC
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\031917-25537-01.dmp
C:\Users\Martin\AppData\Local\Temp\WER-37970-0.sys data.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clci d=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Neviem či je to SW alebo HW može mi niekto povedať ? tu je ten minidump
<?xml version="1.0" encoding="UNICODE"?>
-<SYSTEMINFO>
-<SYSTEM>
<OSNAME>Windows 7 Ultimate Professional</OSNAME>
<OSVER>6.1.7601 1.0</OSVER>
<OSLANGUAGE>1051</OSLANGUAGE>
<ARCHITECTURE>9</ARCHITECTURE>
<PRODUCTTYPE>1</PRODUCTTYPE>
</SYSTEM>
<MEMORYDIAGNOSTIC> </MEMORYDIAGNOSTIC>
-<DEVICES>
-<DEVICE>
<DESCRIPTION>ACPI Thermal Zone</DESCRIPTION>
<HARDWAREID>ACPI\ThermalZone</HARDWAREID>
</DEVICE>
-<DEVICE>
<DESCRIPTION>Generic volume shadow copy</DESCRIPTION>
<HARDWAREID>STORAGE\VolumeSnapshot</HARDWAREID>
</DEVICE>
-<DEVICE>
<DESCRIPTION>Generic USB Hub</DESCRIPTION>
<HARDWAREID>USB\VID_8087&PID_0024&REV_0000</HARDWA REID>
<SERVICE>usbhub</SERVICE>
<DRIVER>usbhub.sys</DRIVER>
</DEVICE>
-<DEVICE>
</DEVICE>
-<DEVICE>
<DESCRIPTION>IDE Channel</DESCRIPTION>
<HARDWAREID>Intel-1c08</HARDWAREID>
<SERVICE>atapi</SERVICE>
<DRIVER>atapi.sys</DRIVER>
</DEVICE>
Z toho, co jsi poslal toho moc nezjistis. Bud si stahni DMP file analyzer a zjisti, co zpusobuje problem nebo si precti informace primo na BlueScreen - tam je cislo chyby, obvykle i jmena souboru ovladace, ktere chybu zpusobily.
úplně typické.
může to být vadná tajná grafika, ale úplně stejně i nenainstalované ovladače základní desky - vypisuje ti to samé periferie chipsetu.
poštvi na to raději: nirsoft bsod viewer.
mimidump výpis může mít 64kb, to jsi sem dal hodně stručný výcuc.
Ano dakujem za odpoveď musel som dat len ten začiatok lebo sa to sem nedalo dať cele lebo to bolo moc dlhe toto spravil ten analyser
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa800564f4e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88003e0ccac, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
FAULTING_IP:
atikmpag+ccac
fffff880`03e0ccac 4883ec28 sub rsp,28h
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`03c06888 fffff880`040a7140 : 00000000`00000116 fffffa80`0564f4e0 fffff880`03e0ccac 00000000`00000000 : nt!KeBugCheckEx
fffff880`03c06890 fffff880`040a6e4a : fffff880`03e0ccac fffffa80`0564f4e0 fffffa80`052bec00 fffffa80`0490e410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`03c068d0 fffff880`0414df13 : fffffa80`0564f4e0 00000000`00000000 fffffa80`052bec00 fffffa80`0490e410 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`03c06900 fffff880`04177cf1 : 00000000`ffffffff 00000000`00000518 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`03c069e0 fffff880`04176437 : 00000000`00000102 00000000`00000001 00000000`00000518 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`03c06a10 fffff880`041492d2 : ffffffff`ff676980 fffffa80`0490e410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`03c06ab0 fffff880`04175ff6 : 00000000`00000000 00000000`0000000f 00000000`00000080 fffffa80`0530b728 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`03c06bc0 fffff800`02f75d6a : 00000000`03ad3dd5 fffffa80`055aa760 fffffa80`036ee450 fffffa80`055aa760 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`03c06c00 fffff800`02cc8266 : fffff800`02e54e80 fffffa80`055aa760 fffff800`02e62cc0 fffff880`031a8150 : nt!PspSystemThreadStartup+0x5a
fffff880`03c06c40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+ccac
SYMBOL_NAME: atikmpag+ccac
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 55c01884
FAILURE_BUCKET_ID: X64_0x116_IMAGE_atikmpag.sys
Followup: MachineOwner
bugcheck 116 spôsobuje nekompatibilný,poškodený ovládač ku grafickej karte,ale aj miestne prehrievanie grafickej karty v zle vetranej skrini..pokial má grafika aktívnu funkciu hypermemory alebo turbocache,môže túto chybu vyvolať aj vadná systémová pamäť,kam hypermemory/turbocache pristupuje,takže prekontroluj najprv počítač pomocou memtest programu,pokial sa tam nenájde chyba,použi ovládače pre grafickú kartu od výrobcu grafickej karty/nie od výrobcu graf.čipu/ a zároveň prekontroluj jej zapojenie-či sa nevysunula zo zbernice,či má všetky potrebné prídavné napájcie konektory korektne zapojené a čii má vôbec pc adekvátny zdroj,ktorý utiahne celú zostavu aj s menšou rezervou....
ďakujem za radu idem na to zroj je určite dobrý počítač fungoval už tak 2 roky
No dobre problem je stale rovnaký ten memtest nenašiel žiadnu chybu a počitač ide stale zapnut len v safe mode a nejde nainstalovat ovladač na grafiku ani z originalneho cdčka že nemoze najst niaky driver či čo
stále předpokládám vadně / vůbec nenaistalovaný chipset driver k desce.
odkdy to dělá a co se v té době změnilo?
