Pc komponenty pomoc
Ahojte,
Chcel by som sa poradit, dako extra sa v PC nevyznam, chcem si poskladat vlastny. Prevazne na hry a aby mi zopar rokov i vydrzal.
Treba mi este daku chladic? Grafiku mam MSI R9 280x Gaming 3G https://www.msi.com/Graphics-card/R9-280X-GAMING-3 G.html#hero-specification Treba novu?
Procesor: Intel Core i5 - 7600K - https://www.alza.sk/intel-core-i5-7600k-d4624244.h tm?catid=18842843&layoutAutoChange=1#popis
Doska: MSI Z270 TOMAHAWK - https://www.alza.sk/msi-z270-tomahawk-d4652323.htm ?catid=18857891#popis
Ram: Kingston 16 GB KIT DDR4 3200 MHz CL16 HyperX Predator Series https://www.alza.sk/kingston-16gb-kit-ddr4-sdram-3 200mhz-cl16-hyperx-predator-series-d4300649.htm?ca tid=18858911
SSD Disk: Samsung 850 EVO 250GB - https://www.alza.sk/samsung-850-evo?dq=2288264&cat id=18856084
HDD Disk: WD Blue 2TB - https://www.alza.sk/wd-blue-2tb-d2922067.htm?catid =18851421#popis
Zdroj: EVOLVEO G550 čierny - https://www.alza.sk/evolveo-g550-cierny-d4562826.h tm?catid=18849164#popis
Case: Corsair SPEC-ALPHA Carbide Series - https://www.alza.sk/corsair-spec-alpha-carbide-ser ies-d4304681.htm?catid=18849057#popis
Chladic: https://www.alza.sk/silentiumpc-fera-3-he1224-d407 6308.htm?catid=18860556#popis
Dakujem za pomoc :)
Zdroj je vyslovene spatnej, nebrat.
Zvaz SSD+HDD, na 250GB toho moc nedas a HDD beres datove pomale 5400ot., pokud na nej pujdou hry, musi byt 7200ot. HDD nebo poridit velky SSD 1000GB, ten ale bude drahy.
jinak OK, grafika zatim urcite staci co mas.
https://www.alza.sk/seasonic-g-series-550w-d458027 .htm?catid=18849164
