Překlad článku
Prosím o překlad tohoto článku. Je to z manualu k desce. Neumím anglicky ani koukat. Díky
DDR Introduction
Established on the existing SDRAM industry infrastructure, DDR (Double Data Rate) memory is a high
performance and cost-effective solution that allows easy adoption for memory vendors, OEMs and
system integrators.
DDR memory is a sensible evolutionary solution for the PC industry that builds on the existing
SDRAM infrastructure, yet makes awesome advances in solving the system performance bottleneck by
doubling the memory bandwidth. DDR SDRAM will offer a superior solution and migration path from
existing SDRAM designs due to its availability, pricing and overall market support. PC2100 DDR memory
(DDR266) doubles the data rate through reading and writing at both the rising and falling edge of the clock,
achieving data bandwidth 2X greater than PC133 when running with the same DRAM clock frequency.
With peak bandwidth of 2.664GB per second, DDR memory enables system OEMs to build high
performance and low latency DRAM subsystems that are suitable for servers, workstations, high-end
PC's and value desktop SMA systems. With a core voltage of only 2.5 volts compared to conventional
SDRAM's 3.3 volts, DDR memory is a compelling solution for small form factor desktops and notebook
applications.
Reklamní kecy, pro uvedení desky do chodu naprosto zbytečné.
Zhruba to samé, ale česky:
ddr.php
díky moc
kecá..... kecá..... ještě furt kecá..... už dokecal.
