Problém s JS
Dobrý den, mám takový problém s Javascriptem. Vůbec nereaguje na webových stránkách a v prohlížeči google chrome když dám Console tak mi vypisuje hlášku: Uncaught ReferenceError: $ is not defined at index.html:10. Prosím o radu.
Celý JavaScript(je nalinkovaný jako externí soubor v html):
$(document).ready(function() {
$('.open-overlay').css('pointer-events', 'none');
var overlay_navigation = $('.overlay-navigation'),
top_bar = $('.bar-top'),
middle_bar = $('.bar-middle'),
bottom_bar = $('.bar-bottom');
overlay_navigation.toggleClass('overlay-active');
if (overlay_navigation.hasClass('overlay-active')) {
top_bar.removeClass('animate-out-top-bar').addClas s('animate-top-bar');
middle_bar.removeClass('animate-out-middle-bar').a ddClass('animate-middle-bar');
bottom_bar.removeClass('animate-out-bottom-bar').a ddClass('animate-bottom-bar');
overlay_navigation.removeClass('overlay-slide-up') .addClass('overlay-slide-down')
overlay_navigation.velocity('transition.slideLeftI n', {
duration: 300,
delay: 0,
begin: function() {
$('nav ul li').velocity('transition.perspectiveLeftIn', {
stagger: 150,
delay: 0,
complete: function() {
$('nav ul li a').velocity({
opacity: [1, 0],
delay: 10,
duration: 140
$('.open-overlay').css('pointer-events', 'auto');
} else {
top_bar.removeClass('animate-top-bar').addClass('a nimate-out-top-bar');
middle_bar.removeClass('animate-middle-bar').addCl ass('animate-out-middle-bar');
bottom_bar.removeClass('animate-bottom-bar').addCl ass('animate-out-bottom-bar');
overlay_navigation.removeClass('overlay-slide-down ').addClass('overlay-slide-up')
$('nav ul li').velocity('transition.perspectiveRightOut', {
stagger: 150,
delay: 0,
overlay_navigation.velocity('transition.fadeOut', {
delay: 0,
duration: 300,
opacity: [0, 1],
delay: 0,
duration: 50
A máš tam i jQuery?
Ano, v html mám podle návodu: <script src="//ajax.googleapis.com/ajax/libs/jquery/1.9.1/ jquery.min.js"></script>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.9.1/ jquery.min.js"></script>
A ten skript se opravdu spouští až ve chvíli, kdy je to jQuery už načtené?
Skript se spouští ihned po načtení stránek. Můj kód:
V adrese máš mezeru za lomítkem a před jquery.min.js což způsobí 404 a nenačte jQuery.
Mezera je pouze tady na webu, ale v souboru mám vše Ok.
Bude tady nějaká hodná duše, která se na to mrkne? Tady je celý projekt. Děkuju.
https://drive.google.com/file/d/0B-iiBUoJQtj6VUprZ TNCcm1peVU/view?usp=sharing
Mně se to načte dobře a spadne to až ve skriptu na:
Poupravil jsem to a teď to visí na tom co jste psal. Nevíte co s tím? :)
Asi ti tam chybí ještě nějaká knihovna.
Mas to v pohode, ale priste kdyz uz si "pujcujes" nekoho praci, aspon to zkopiruj poradne
Do importu hod tohle:
<script src="http://julian.com/research/velocity/build/jquery.v elocity.min.js"></script>
<script src="http://julian.com/research/velocity/build/velocity .ui.js"></script>
Děkuji, pomohl jsi mi. Jedná se o volně stažitelný projekt.
