danger from deep, pomoc s instalací
dobrý den, mám problém s instalací hry danger from deep.
Stáhl jsem si soubor dangerdeep-0.3.0-linux-installer.bin
z těchto stránek
downloads
hru jsem úspěšně nainstaloval, hra se mi normálně spustí(spustil jsem ji příkazem dangerdeep_x86-64)
, ale když hrát misi, tak se hra vypne a v termnálu mám tuhle hláškou:
dangerdeep_x86-64
OpenGL vendor : X.Org
GL renderer : Gallium 0.4 on AMD KABINI
GL version : 3.0 Mesa 10.5.9
GL max texture size : 16384
GL number of texture units : 8
GL number of lights : 8
GL number of clip planes : 8
GL maximum viewport dimensions : 16384x16384
GL depth bits (current) : 24
Supported GL extensions :
GL_ARB_multisample
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_vertex_array
GL_EXT_compiled_vertex_array
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_gpu_program_parameters
GL_EXT_texture_array
GL_EXT_texture_compression_latc
GL_EXT_texture_integer
GL_EXT_texture_sRGB_decode
GL_EXT_timer_query
GL_OES_EGL_image
GL_ARB_copy_buffer
GL_ARB_depth_buffer_float
GL_ARB_draw_instanced
GL_ARB_half_float_vertex
GL_ARB_instanced_arrays
GL_AMD_shader_stencil_export
GL_ARB_shader_stencil_export
GL_ARB_shader_texture_lod
GL_ARB_texture_cube_map_array
GL_ARB_texture_gather
GL_ARB_texture_multisample
GL_ARB_texture_query_lod
GL_ARB_texture_rgb10_a2ui
GL_ARB_uniform_buffer_object
GL_ARB_vertex_type_2_10_10_10_rev
GL_EXT_provoking_vertex
GL_EXT_texture_snorm
GL_MESA_texture_signed_rgba
GL_NV_texture_barrier
GL_ARB_get_program_binary
GL_ARB_robustness
GL_ARB_separate_shader_objects
GL_ARB_shader_bit_encoding
GL_ARB_texture_compression_bptc
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_NV_vdpau_interop
GL_ANGLE_texture_compression_dxt3
GL_ANGLE_texture_compression_dxt5
GL_ARB_base_instance
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_internalformat_query
GL_ARB_map_buffer_alignment
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_texture_storage
GL_ARB_transform_feedback_instanced
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_transform_feedback
GL_AMD_shader_trinary_minmax
GL_ARB_clip_control
GL_ARB_texture_barrier
GL_EXT_polygon_offset_clamp
GL_KHR_context_flush_control
console log: $ffffffDanger $c0c0c0from the $ffffffDeep
console log: $ffff00copyright and written 2003 by $ff0000Thorsten Jordan
console log: $ff8000version 0.3.0
console log: $80ff80*** welcome ***
console log: New thread [0xddb2f700]
console log: Loading...
console log: Textures with non-power-two sizes are supported and used.
console log: fonts loaded (238ms)
console log: textures loaded (99ms)
console log: Music list loaded (104ms)
console log: Using OpenGL GLSL shaders...
console log: shader compiled successfully, log:
console log:
console log:
console log: compiling failed, log:
console log: 0:3(1): preprocessor error: #version must appear on the first line
console log: End thread [0xddb2f700]
Caught exception: compiling of shader failed : /usr/share/games/dangerdeep/shaders/modelrender.vs hader
Stack trace: (5 frames)
0x42c906 in at ??:?
0x42a046 in at ??:0
0x42a10a in at ??:0
0x3e35221f45 in __libc_start_main at ??:0
0x4096b9 in __gxx_personality_v0 at ??:0
předem díky za radu co s tím, aby mi hra šlapala..
Nechybi ti nahodou libSDL_image-1.2.so.0 a libfftw3f.so.3?
nevím co to je? Jak to stáhnu a nainstaluji.
PS: mám linux mint 17.3 xfce
