grafika agp 8X do agp 2X
zdravím! prosím vás dá se připojit grafika agp 8x do slotu agp 2x ???
Předmět | Autor | Datum |
povidani o agp z wikipedia.org:
AGP cards are backward and forward compatible within limits. 1.5 V-… gullman 21.03.2008 18:07 |
gullman | |
a nevis jestli by to zvladlo ati radeon 9200? Petar Kovač 21.03.2008 18:58 |
Petar Kovač | |
nevim :-) ...nevim co to je za desku (ten tvuj Mikrostar z druheho vlakna?) ... vyzkousej a uvidis.… gullman 21.03.2008 19:01 |
gullman | |
to je zase jina...siemens ag d1107, radsi nebudu riskovat...ale ten mikrostar - na netu jsem nasel z… Petar Kovač 21.03.2008 19:11 |
Petar Kovač | |
Připojit ji tam můžeš, ale pak nenadávej, že máš odhulenej počítač :-) poslední marekdrtic 21.03.2008 19:35 |
marekdrtic |
AGP cards are backward and forward compatible within limits. 1.5 V-only keyed cards will not go into 3.3 V slots and vice versa, though "Universal" slots exist which accept either type of card. AGP Pro cards will not fit into standard slots, but standard AGP cards will work in a Pro slot. Some newer cards, like Nvidia's GeForce 6 series or ATI's Radeon X800 series, only have keys for 1.5 V to prevent them from installing in older mainboards without 1.5 V support. Some of the last modern cards with 3.3 V support were the Nvidia GeForce FX series and the ATI Radeon 9500/9700/9800(R350) (but not 9600/9800(R360)).
It is important to check voltage compatibility as some cards incorrectly have dual notches and some motherboards incorrectly have fully open slots. Furthermore, some poorly designed older 3.3 V cards incorrectly have the 1.5 V key. Inserting a card into a slot that does not support the correct signaling voltage may cause damage.
obrazek s ruznymi agp sloty navzajem nekompatibilnimi podle napajeni zde:
http://en.wikipedia.org/wiki/Image:AGP_%26_AGP_Pro_ Keying.svg
nevim ...nevim co to je za desku (ten tvuj Mikrostar z druheho vlakna?) ... vyzkousej a uvidis. Viz muj prispevek nahore
to je zase jina...siemens ag d1107, radsi nebudu riskovat...ale ten mikrostar - na netu jsem nasel ze podporuje agp 3.3/5 V a jestli ty nove graficke karty jedou na 1.5 V tak tam asi nic noveho nepripojim co?
