Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem rozdiel medzi logical grouping and physical layout
Ahojte. Vedel by mi niekto rozumne vysvetlit rozdiel medzi physical and logical structure? Najlepsie by bolo keby to vysvetlil na 1 konkretnom pripade ze co sa berie ako logical a co ako physical struktura. Snazil som sa tomu porozumiet v MCDST training kit kde bolo toto:
Workgroups,domain and multiple domains describe the logical grouping of computers. Don't confuse the logical grouping with physical layout of network.A small network of three computers connected by single hub can be logically grouped into the domain, just as a larger network consisting of thousands of computers across multiple subnets can also be grouped into a domain.The reason for the restriction between logical and physical structures is one of abstraction.The physical layout has to do with where computers are located and how they are connected to the network. The logical layout has to do with the function of the computer, how it is used, and how it is managed.By separating the two, the administration of computers does not have to be affected by network infrastructure.
Ide mi vlastne o to aby som pochopil rozdiel mezdi pracovnou skupinou a domenou. Zatial tomu chapem tak ze domena je skupina pocitacou ktora je napojena na jeden alebo aj viac serverov a prac. skupina je ked su pocitace zapojene medzi sebou cez hub alebo router.Asi v tom mam bordel.
Diky za vysvetlenie.
odpovedam na povodnu otazku (ktoru mas v titulku): fyzicky (physical) layout je o tom ze ktore PC s…
MM.. 31.03.2008 16:17
Diky za vysvetlenie. Po anglicky neviem perfektne ale zase nie som ani zaciatocnik.Zijem uz 4 roky v…
rasto 31.03.2008 17:16
rasto
A preco to chces zodpovedat? :-) Sak to je prave to co mas vediet, ak ich nevies zodpovedat tak to z… poslední
MM.. 31.03.2008 17:26
Pracovni skupina je spojeni pocitacu, ktere sdili urcite prostredky (disky, tiskarny, ...) Mohou byt…
Jan Fiala 31.03.2008 17:14
Jan Fiala
fyzicky (physical) layout je o tom ze ktore PC su kde fyzicky umiestnene a ze ako su spojene (napr. mam 3 PC v prahe a 3 PC v brne a su spojene tak a tak)
logicke zoskupovanie je o tom ze rozdelit si pocitace do skupin napr. podla toho ake maju mat prava, akym sposobom sa maju jednotlive skupiny PC spravovat, kam logicky patria, napr. z uvedenych 3PC v prahe a 3PC v brne mozu byt 2PC z prahy a jedno PC z brna pre obchodnikov a zvysne PC (jedno z prahy a dve z brna) pre technikov, takze si ich rozdelis na logicke skupiny "obchodnici" a "technici", a nezavisi to od toho ze kde su fyzicky umiestnene.
- to co som tu napisal mas jasne napisane v tom anglickom texte, nechces sa najprv radsej zdokonalit v anglictine? Lebo asi anglictine moc nerozumies...
P.S. na rozdiel medzi pracovnou skupinou a domenou sa opytaj nejakeho admina (resp. zadaj otazku taku ze na co sa pytas a nepis do titulku otazku uplne inu). Alebo si to precitaj v tom dokumente, ale nie v tom odseku ktory si tu odcitoval, v nom to napisane nie je.
Diky za vysvetlenie. Po anglicky neviem perfektne ale zase nie som ani zaciatocnik.Zijem uz 4 roky v Londyne tak sa na mna uz daco za ten cas prilepilo,Pravdaze by sa mi to lepsie studovalo v slovencine, no taku moznost bohuzial nemam:-/
Vadilo by ti zodpovedat tieto otazky a keby si k tomu pridal kratky comment,ze preco si to tak dal, bolo by super.
For each of the following description, decide whether if refers to a workgroup, a domain, or a multiple domain network configuration. If the description applies to more than one network configuration, list all that apply:
1-This network configuration is a logical grouping of computers created for purpose of sharing resourses such a files and printers
2-This network conf. does NOT use Active Directory servises
3-This network conf. provides a single point of administration for security
4-This network conf. CAN include multiple domain controllers.
5-This network conf. is easy to design and implement, and is best configured for users in close proximity to one another.
A preco to chces zodpovedat? :-) Sak to je prave to co mas vediet, ak ich nevies zodpovedat tak to znamena ze to nevies, ale ak ti ich zodpovie niekto iny, tak sa to z tych odpovedi rozhodne nenaucis. Tema administracie domeny nie je na 3vety, treba si o tom najprv nieco obsirnejsie precitat, zacat mozes trebars aj googlom a zadat si domena pracovna skupina alebo aj si najst slova domain a workgroup na wikipedia.com apod.
Uz ti zodpovedal JaFi nizsie, ja nie som administrator takze tiez ti mozem povedat len uplne zhruba ze prac.skupina je len zosietovane viacerych PC ktore si nieco medzi sebou zdielaju, jednoduche na vytvorenie ale nemozes to centralne administrovat a ma to mnoho obmedzeni. Domena ma domenovy server ktory napr. overuje prihlasovanie, urci co dany pouzivatel moze a co nemoze, t.j. spravujes potom vsetkych z jedneho bodu - na domenovom serveri. Tolko laicke vysvetlenie od ne-admina (to akoze ja :)
O multiple-domain konfiguraciach nemam sajnu.
Mohou byt a nemusi byt pripojeny na server - v podstate vsechny pocitace v pracovni skupine jsou si rovny. Pracovni skupina nema zadnou centralizovanou spravu.
Domena naopak centralizovanou spravu umoznuje - rizeni pristupu, overovani, rozdelovani do logickych celku, skupin, ...
