Zvysenie timeout u Postfixu
Potreboval by som zvysit timeout pre klientov, pretoze sa im sem tam stane, ze ked posielaju vacsi mail dostanu hlasku o ukonceni spojenia zo serverom.
Předmět | Autor | Datum |
smtp_data_xfer_timeout (default: 180s)
The SMTP client time limit for sending the SMTP message conte… poslední touchwood 07.05.2008 13:16 |
touchwood |
The SMTP client time limit for sending the SMTP message content. When the connection makes no progress for more than $smtp_data_xfer_timeout seconds the Postfix SMTP client terminates the transfer.
Time units: s (seconds), m (minutes), h (hours), d (days), w (weeks). The default time unit is s (seconds).
viz: http://www.postfix.org/postconf.5.html#smtp_connect _timeout
