Nová grafická karta
Dobrý den. Již nějakou přemýšlím nad koupí nové grafické karty ( EVGA GeForce GTX 1060 FTW GAMING, 6GB GDDR5 - https://www.czc.cz/evga-geforce-gtx-1060-ftw-gaming-6gb-gddr5/216883/produkt ) , ale nejsem si zcela jist, zda by spolupracovala s mou základní deskou ( DP67DE - zřejmě tato https://www.alza.cz/intel-dp67de-deer-flat-stepping-b3-d222263.htm ) . Prosím o pomoc.
Toto jsou bližší specifikace mého pc : Computer Information:
Manufacturer: INTEL_
Model: DP67DE__
Form Factor: Desktop
No Touch Input Detected
Processor Information:
CPU Vendor: GenuineIntel
CPU Brand: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
CPU Family: 0x6
CPU Model: 0x2a
CPU Stepping: 0x7
CPU Type: 0x0
Speed: 3093 Mhz
4 logical processors
4 physical processors
HyperThreading: Unsupported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Unsupported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
CMPXCHG16B: Supported
LAHF/SAHF: Supported
PrefetchW: Supported
Operating System Version:
Windows 7 (64 bit)
NTFS: Supported
Crypto Provider Codes: Supported 311 0x0 0x0 0x0
Video Card:
Driver: AMD Radeon HD 5670
DirectX Driver Name: aticfx32.dll
Driver Version: 13.152.0.0
DirectX Driver Version: 8.17.10.1230
Driver Date: 8 30 2013
OpenGL Version: 4.2
Desktop Color Depth: 32 bits per pixel
Monitor Refresh Rate: 60 Hz
DirectX Card: AMD Radeon HD 5670
VendorID: 0x1002
DeviceID: 0x68d8
Revision Not Detected
Number of Monitors: 2
Number of Logical Video Cards: 2
No SLI or Crossfire Detected
Primary Display Resolution: 1920 x 1080
Desktop Resolution: 3600 x 1080
Primary Display Size: 26.65" x 15.00" (30.55" diag)
67.7cm x 38.1cm (77.6cm diag)
Primary Bus Type Not Detected
Primary VRAM: 1024 MB
Supported MSAA Modes: 2x 4x 8x
Sound card:
Audio device: Reproduktory (Realtek High Defi
Memory:
RAM: 10219 Mb
Miscellaneous:
UI Language: English
Media Type: DVD
Total Hard Disk Space Available: 953767 Mb
Largest Free Hard Disk Block: 183532 Mb
OS Install Date: 1 01 1970
Game Controller: None detected
VR Headset: None detected
Fungovat bude. Horší je, že ta karta není skladem.
Ok. Nějakou dobu ještě kupovat nebudu. Takže do té doby jí snad naskladní. Každopádně šlo víceméně o to, jestli ta motherboard pojede s nějakou výkonnější grafikou, nebo bude třeba kupovat i motherboard. Takže bych třeba nakonec vybral jinou. Díky za odpověď :)
