Detrollizer na pnet...
Ahoj,
upravena verze detrollizeru z debat, tak aby fungovala pro poradnu. Zacina to byt treba i tady. Enjoy!
PS: Pripadne bugy opravim...
Script pro Greasemonkey:
// ==UserScript==
// @name Detrollizer pro poradna.net
// @version 1
// @grant none
// @require http://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js
// ==/UserScript==
// Script schova prispevky a vlakna zvolenych useru.
// U prispevku se vyuziva tag spoiler, aby nedoslo k naruseni struktury vlakna. Vlakna jsou odebrana z tabulky threadu.
// nastav promennou na true, pokud chces schovat hodnoceni prispevku
var HIDE_POST_RATING = false;
// nastav prezdivky useru, jejichz prispevky a vlakna chces schovat
// funguje pro registrovane i neregistrovane usery
var BLOCKED_USERS = ["Mlocik97", "MaSíčko"];
$(function () {
hidePostsRatings();
hideThreads();
hidePosts();
function hidePostsRatings() {
if (HIDE_POST_RATING) {
$("a.rate").hide();
function isBlocked(login) {
for (var i = 0; i < BLOCKED_USERS.length; i++) {
if (BLOCKED_USERS[i] === login) {
return true;
function hideThreads() {
$("td._createdBy").each(function () {
var nickElement = $(this).find("a:first");
var nickText = null;
if ($(this).has("a").length) {
nickText = nickElement.html();
} else {
nickText = $(this).html();
if (isBlocked(nickText)) {
$(this).parent().hide()
function hidePosts() {
$("article.reply").each(function () {
var nickElement = $(this).find("b:first");
if (nickElement.has("a").length) {
nickText = $(this).find("a:first").html();
} else {
var postElement = $(this).find("div.body:first");
var postContent = postElement.html();
postElement.empty();
postElement.append(detrollizePostContent(postContent))
$('div.detrollizer').detrollize();
function detrollizePostContent(content) {
return '<div class="detrollizer" style="display : none">' + content + '</div>'
(function ($) {
$.fn.detrollize = function (settings) {
settings = jQuery.extend({
text: 'Detrollized!'
}, settings);
this
.wrap('<div class="spoiler-wrapper" />')
.parent()
.prepend(
$('<div class="spoiler_title">')
.click(function () {
$(this).parent().toggleClass('spoiler-expanded');
$(this).next('.detrollizer').slideToggle();
.text(settings.text)
return this;
})(jQuery);
Na pár dní to připnu.
Ok. Pak mozna kategorie Pokec nebyla nejstastnejsi volba...
Par dni, to je ako docastne. Dnes hakliva tema (50-te vyrocie) jednotka docastnosti je jeden furt.
"Občas se divím, že lidstvo dokázalo vylézt z jeskyní" - no trocha to trvalo, nebol dostatocny signal GPS.
Prajem pekne rano.
Máš pravdu, pár dní uplynulo.
dobrá práce
Nabizim jednoduchy skriptik pro GreaseMonkey, ktery vas varuje, ze je vlakno prilis stare. Motivace je zabranit exhumaci, nebo aspon reakcim na exhumovana vlakna.
Snaha se cení.
Ale obávám se, že cílové skupině uživatelů to bude jedno - buď skript nezvládnout použít nebo i kdyby měli nápis přes celou obrazovku, stejně je to neodradí, aby vlákno exhumovali.
Ono se to hodi i mne. Abych do exhumacu sam nereagoval, pac datum se da snadno prehlednout...
Data příspěvků jsou odlišeny barvou podle stáří.
Ve skinu dark nic takoveho nemam...
Reklamuj u autora skinu.
Nebo vytvoř svůj...
