Nenapsal jsi zásadní informace - jaké ovladače jsi instaloval, jaký máš operační systém, jakou máš grafiku...?
windows 10 Grafika NVIDIA GeForce GTX 950 ovladače verze 441.66
Nemáš přetaktovaný procesor? Jakou máš verzi DirectX? (příkaz dxdiag)
Nasel jsem tento navod. Mohlo by to byt reseni, tak jsem dle toho postupoval a prozatim vse ok. Otazka jestli je to nahoda nebo tento postup to opravud mohl opravit, to ovsem nejsem se svymy znalostmi schopen posoudit.
If anyone else has encountered this problem on FIFA20, a person from NVIDIA was extremely helpful in an online support chat:
Please create a profile for Fifa20 on NVIDIA Control Panel by following the steps below.
Open NVIDIA control panel (Right click on desktop and click NVIDIA control panel) > Go to Manage 3D settings under 3D Settings > Select Program settings :
> Under Step 1 select Fifa20 (If you do not find it, click Add and add the .exe file of the application to the list)
> Under Step 2 select High-performance NVIDIA processor.
> Change the following settings under Step 3.
• Power management mode - Prefer maximum performance
• Threaded optimization - ON
• Triple buffering - Off
• Vertical Sync - Off
Click on "Apply" to save the changes
This fixed any crashes for me which was previously occurring every half hour or so.
